ok guys, heres the deal....
my headers and spoiler we delivered monday and are getting installed this weekend, so theres some good news. i also have been doing some "research" and here is what i've come up with.....
i wanted to wait until AFTER the headers/y-pipe install to post this so i could include an evaluation of the header setup as well, but ill go ahead and get this started now. the headers/y-pipe are stainless steel and look very nice. im not exactly sure of performance gains but will post those later. i told you i would send you guys a link about this setup so here are a few pages with info to look at...
1)
http://forums.maxima.org/showt...pp=302)
http://forums.maxima.org/showthread.php?t=2739953)
http://www.vqpower.com/v2/modu...id=884)
http://cgi.ebay.com/ebaymotors...QrdZ1 (these are a set like the ones i bought)
ok so i hope that helps with the headers. now for the ecu. i have concluded that if you own a later model 4th gen (97-99) then you are just skrewed. JET offers a package where you send in YOUR stock ecu to be reprogrammed. i personally called them this morning and was told that it is dyno-ed to add 15 hp and 12 lbs torque at the wheels. sounds like a good deal for $399 (from JET) or $350 (from CustomEnterprise). however, they cannot remove or raise the speed limiter found on the gle and gxe models, which was my primary reason for doing the mod. so then i called Jim Wolf Tech. i was told by them that they can reprogram 95-96 maxima with auto or manual transmission's. they could also do 97 ecu with manual by altering a 96 ecu to fit. but they couldnt do a 98-99 ecu because it was wired into the anti-theft system and some other technicalities. so....there you have.
does ANYONE has ANY idea how to get rid of that cursed speed limiter WITHOUT lighting up check engine lights please let me know. i also called a local tune shop (crawford z) and was told tunning gives such a minimal addition that its not even worth the effort. can anyone give any other advice????
Modified by nismo1219 at 11:50 AM 8/2/2006
