xharobikeslifex wrote:thanks i called him and got me some fabric on the way So i was removing the fabric on the door panels and it looks like u have to be precise in cutting out the fabric im curious to see how u go about it
Well, you don't have to be exact at all.
Things needed: A small 90 degree hook pick, 3M blue masking tape, 3M Super Trim Adhesive(probably can't buy this in the stores), razor blade, adhesive remover and some newspaper/packing paper/plastic etc.(anything to cover up the door card where you don't want glue)
1st: Clean the area REALLY well with adhesive remover (I like 3M).
2nd: Use blue 3M masking tape to tape off the area to be glued. -You need to tape to the outside vertical wall of the valley. -I use a long piece of tape on the straights and a bunch of small pieces around the radius. -I use the 90 degree pick to help push the tape onto the vertical wall. -then fold over the tape onto the door card. -next tape paper etc. onto the tape that is folded over to mask off the entire door card.
3rd: Spray adhesive onto the area not taped off and onto the material being used. -don't worry about getting spray adhesive past where you need it on the material....actually it is recommended. -you will let the adhesive set up per directions.... usually at least 5 minutes, but no longer than 60 minutes.
4th: Next pull off all the paper and tape.
5th: Apply your material onto the card. Make sure it is big enough to cover each direction by several inches. -note: the glue will only stick to itself. So that's why it doesn't matter that you have extra glue on the material.... because it will not stick onto any of the plastic that doesn't have glue.
6th: Work the material onto the card making sure to stretch this way and that so you do not get any wrinkles etc. -use a lot of force to work the material onto the card.... ESPECIALLY in the corners. -keep applying pressure as you rub your fingers, thumb whatever back and forth over the material. -even after step 8, I will still keep rubbing the material onto the card firmly.....ESPECIALLY in the corners. -even after I wake up the next morning, I will go over it again applying pressure. -most glues don't fully cure for 24 hours at 75 degrees. -the material should extend at least a few inches past the valley.
7th: Use the hook pic to push the material all the way down into the valley.-Obviously make sure not to catch the end of the pic on the material. I use it at an angle so the end is sticking out of the valley. -you can usually just pull or push the pic through the valley and it will pull the material down in. -so you will obviously have extra material sticking out of the valley now.
8th: Take a razor blade and carefully run it around down inside the valley. -this will make a perfect cut down inside there and the extra material will come right off. -I like to wrap the same blue masking tape around the razor blade except for the last 1/4" of the tip. -that way the rest of the blade has no chance of catching on the material on the walls of the valley.
Finished product with perfect results:
Modified by Broadfield at 12:14 AM 6/15/2009
