Broadfield »
https://forums.nicoclub.com/broadfield-u46569.html
Sun Apr 26, 2009 1:14 pm
Thought I would post a little update. Finally got around to starting the upholstery work on the back seat.
Since I have a junk back seat, I am stripping all of the material down to individual panels. This means I can trace each individual pattern onto my new material. So in the 1st pic, I numbered each panel and made a "map" of the seat panels. I then carefully seam ripped every panel until everything was apart.
These are some pics of material that I have already cut to shape. I basically pinned the old panel to the new material and used a rotary cutter to cut around the panel. There will be a stitch that cuts across the middle of this panel to make the dividing line between panel 9 and 10. In this example, panels 9 and 10 are actually one piece of material, but with a stitch across it like I mentioned above. So the finished product looks like two separate panels.
Same goes for this pic..... one piece of material, but actually three panels. Here you can see where I already stitched to divide the panels. This would be 5, 6 and 7 from the first pic.
These are the 3 and 11 panels from the first pic.... these would be the sides bolsters of the seat bottom.
..... and this is where all the action happens. An old Singer for the win!
It's going to get a lot tougher from here on out. Metal rods have to be sewn in so the material can be hog ringed to the cushion etc..... so it's about to get fun. I am just in the preliminary stuff now. I'll make sure to post pics as I go. I am waiting on some more material, so we'll see how far I get. Then keep in mind I'll have to do the same thing to the back of the back seat.
