So, I just realized I don't have an official build thread haha. For those of you who don't know, my name is Morgan and I was a U.S. Army Paratrooper stationed at Ft. Bragg, NC. I picked up my first 300zx (a 1990 N/A auto) in the Fall of 2005. I fell in love with the 300zx at a young age and have drooled over them since. I drove my N/A as a daily driver for a year or so and then was deployed to Afghanistan. She went into storage for the next year. In the mean time, I researched everything I possibly could about the Z car. I later found a guy selling a 1992 TT manual in Southern Florida. So, after I got back from the Middle East, I took a trip and checked it out. She was in pretty rough shape, but I scored a deal and drove it back up to NC. The fun began and I started major restoration and upgrading. I have since been released from active duty and now reside in Salt Lake City, UT. I am doing a complete engine rebuild and plan to attain about 600whp. I'm happy to answer any questions you may have... enjoy my passion!
-Exterior-
1999 J-spec front fascia
1999 J-spec rear tail lights
eBay clear rear side markers (smoked)
IonicDynamics carbon fiber door pillars
IonicDynamics RT cowl panel
KarumaZ belt moldings
New OEM third brake light panel (debadged)
PowerTrix carbon fiber fog light ducts
Swapped hatch and nose panel from my old 1990 N/A
TwinZ Type II rear bumper with diffuser
-Lighting-
AutoVizion 6000k HID kit
LED rear markers
-Wheels and Tires-
Motegi gunmetal DP10 18x8 Front and Rear (will be changing to a much more aggressive set up)
Nitto NT555 245/40/ZR18 (same as above)
-Braking-
300 Degree master cylinder brace
-Suspension/Steering-
AMS front inner tie rods
Carbing rear strut bar
Concept Z Performance front end links
Energy Suspension bushings
Energy Suspension rear end links
PowerTrix adjustable front upper control arms
PowerTrix adjustable rear upper control arms
PowerTrix adjustable rear traction rods
PowerTrix HICAS eliminator bar
SPL front outer tie rod ends
Stillen front and rear anti-sway bars
Tein Flex coilovers with full EDFC (F-8kg/R-6kg)
Tein pillow-ball tension rods
-Interior-
300 Degree 3 gauge cluster DIN mount
Concept Z Performance polished gauge rings
Custom dash (red) and pod (blue) LED conversion
Custom SMZ replica carbon fiber shift knob
Momo 300zx hub
Momo 300zx seat brackets and sliders
Momo Millennium Evolution steering wheel
Momo Speed II seats in charcoal alcantara
Redline Goods custom shift & e-brake boots in charcoal alcantara laced in green
REV Imports carbon fiber rear seat paneling, center piece and arm rest
-Electronics-
Autometer Cobalt wide band Air/Fuel ratio gauge (x2)
Defi Blue Racer boost gauge
Defi Blue Racer temperature gauge
GReddy Profec B Spec II boost controller
GReddy turbo timer
Tein EDFC
-Deletes-
AIV system
Carbon canister
Cruise control
EGR system
HICAS system (full removal)
PRVR system
Secondary clutch bleeder line
Throttle body water bypass
VTC function
-Drivetrain-
350Z cast iron clutch fork kit
Concept Z Performance stainless steel braided clutch line
Nismo transmission mount
Shaftmasters aluminum one piece drive shaft
Specialty Z High 5-puck clutch
Specialty Z lightweight flywheel
Z1 premium short throw shifter
-Power Plant-
300 Degree fuel rails with stainless steel braided lines
ARP connecting rod bolts
ARP L19 head studs
Blitz oil cap
BDE motor mounts
BDE solid exhaust cam valve cover plugs
Cometic metal head gaskets (0.060 thickness)
Concept Z Performance 2.5" aluminum intercooler piping kit
Concept Z Performance (Concours) polished upper intake plenum (machined inlet ports to 58mm to accommodate the Z1 throttle bodies)
Eagle connecting rods
Holley adjustable fuel pressure regulator with 100psi gauge
Jim Wolf Technology pop charger intake filters (x2)
Jim Wolf Technology tuned ECU
JUN adjustable intake and exhaust cam gears
Koyo Aluminum radiator with CZP stainless brackets
LaMco oil tree sensor adapter
Mike Smith turbo exhaust manifolds
Mild Intake and exhaust port work on heads
Nismo 740cc injectors (95+)
Nismo thermostat at 62ºC (143.6ºF)
OEM 95+ EFI harness, CAS & PTU
Power Enterprise kevlar timing belt
Ramey Z heavy duty idler studs
Selin dual MAF translator with elbow kit
Specialty Z (Sebring) 3" 5 bolt stainless steel expansion down pipes
Specialty Z (Sebring) 3" stainless steel test pipes with dual wideband bungs
Specialty Z (Sebring) 3" stainless steel quad round tipped cat-back
Unknown Coatings powder coated parts in Illusion Green
Unorthodox Racing crank pulley
Unorthodox Racing overdrive water pump pulley
Wiseco pistons bored to 88mm (0.040 over)
Z1 bronze valve guides
Z1 EGR block off plates
Z1 GT675RS turbos
Z1 HL-15 cams (270º duration and 0.385 lift)
Z1 lower radiator hard pipe (chrome) with silicone elbows
Z1 magnetic drain plug
Z1 oil cooler
Z1 polished 58mm throttle bodies
Z1 side mount intercoolers
Z1 silicone accordion hoses
Z1 silicone hoses and lines
Z1 stainless steel engine bay bolt kit
Z1 valve springs
-Miscellaneous/Fluids-
ATE super blue DOT4 clutch & brake fluid
Concept Z Performance battery tray
Dewla Design throttle cable cover strip
HKS Limited Edition Black SSQV blow off valves (x2 recirculated via HKS 29mm fittings)
Redline MT90 transmission fluid
Z1 aluminum door lock actuators (left & right)
And now the pictures!
From this:
To this: (not too bad for a weekend of work!)
Suspension work:
Misc.
Still very much in pieces and a huge work in progress but, I will try to update as often as I can. Thanks for looking!
