And primer...... look on the bright side at least you didn't ruin an S14?derrick113 wrote:tape is your friend.
did you sand the window trim and weather stripping? the taillight too? that s*** just looks lazy. If it makes you happy I'll edit my previous post and give you 60% effort, but its still really lacking. Masking tape is your friend, you can sand all you want but all that "over-roll" makes it look like a hack job.Justin35ll wrote:..how is my prep work 0 i wet sanded the entire car with 400 grit and then 600 grit don't tell me I didn't do any prep work
hpmachine wrote:I've read many articles about painting cars with a small roller. YOu have to thin paint til it's about the consistency of milk and then lay down coat after coat wet sanding between each one. These paint jobs are super cheap and can look like a million bucks if done right. Look at this and then everone can shutup.http://www.rickwrench.com/inde....html
