rioredstang wrote:Check the Steering rack bushings. The steering rack is sliding back and forth in their mounts. Open the hood and have someone turn the steering wheel back and forth. Look down by the brake booster and you can see the top of the rack. While they are turning the wheel the rack should not move. I have seen this many times.
omgjacki wrote:2. Tie rod ends (replaced and installed using the spray paint technique)
Huhhuh Huhuh Jackie said input.omgjacki wrote:Thanks for the input. That was my boyfriend who posted for me. I mentioned the steering rack and bushings many times but he was sure that wasn't it. After everything we've done it's still doing this. So, I'll tell him to swallow his pride and check the rack. Thank you again!
I'll see if we can get to that tonight and I'll update.
That doesn't explain the car yanking to the left in a turn. You obviously haven't ever bent a strut rod. My car yanked during right turns...it was ds strut rod and a arm so A ARM!rioredstang wrote:The only thing I have seen that will affect the centering of the steering wheel like is when the rack is moving. The strut arms being bent would make the car pull to one side or the other. CHECK THE RACK BUSHINGS.
did it also pull when you press on the brake?compactfean wrote:That doesn't explain the car yanking to the left in a turn. You obviously haven't ever bent a strut rod. My car yanked during right turns...it was ds strut rod and a arm so A ARM!
If I had a nickel for every time somebody walked into my shop and told me they needed an alignment because thier steering wheel was shaking, I wouldnt even need to work on cars.driftnasty180sx wrote:BUT i still believe its the alignment because when i drove it home the other day there was alot of shaking in the steering wheel. CLASSIC sign of alignment ...sorry that was one thing i forgot to mention ......Tuesday it goes in for the alignment and then i will post the results....
BUt anything other suggestions will be help to me or anyone else that might have the same problem so keep posting
Ive had problems with the tension rods coming loose at the control arms on S chassis's. If they are not uber tight, hard braking can cause them to slide a little, and once it happens, they just get looser and looser.driftnasty180sx wrote:Yeah the tension rods are deff. good and the tie rod ends are new too..
but you might be right i am gonna check al the bolts and see if something is loose...something could have gotten loose over time....also everything was swapped over from the one chassis to the other (suspension, engine swap, rack, etc) by the shop. Maybe something wasnt tight correctly....
The little shimmy and pulling i believed that a alignment would fix...BUT i just drove the car again just and this earthquake shake couldn't be from just an aligment..so you guys have a very good point... i stand corrected ....hopefully it is just a case of loose bolts....
