fueler wrote:For someone who hasn't even confirmed that their P1444 is gone, you sure give some crazy advice. Driving around a block isn't enough for EVAP readiness.
For someone who assumes I don't know how to make-ready the emission system or test for a DTC, my crazy advice is to re-read what I wrote:
Hawairish wrote: I'm still waiting for a replacement intake tube before taking it on a full drive cycle to fulfill all the readiness tests, but I've also started it up a few times since to confirm it's not in pending, which my scanner detects.
P1444 is a two-trip DTC; the 1st trip puts it in pending without the MIL, and the 2nd consecutive trip stores it and triggers the MIL. My scanner detects both states. You do not need to go on a literal "trip" to throw this code, or many others. You just start it up, wait, shut it off, repeat. Furthermore, you can absolutely throw a code before the emissions systems tests are passed. So yeah, it's confirmed cleared. If you don't believe me, pull the harness on your solenoid, clear your codes, start the truck a couple times, and let us know what happens.
Speaking of which...the R50 uses the exact same solenoid, so I swapped them on Saturday. The R50 has been driven daily since and has not thrown a code with the "problematic" solenoid. The Frontier, with known-working solenoid, has also not thrown a code. Not sure what more proof I can provide for you.
The FSM describes the driving pattern to pass all the readiness tests. I'm quite familiar with it, and it takes me about an hour to do. My scanner also tells me the readiness status of each test. I haven't done it yet because UPS thinks NJ is between TX and AZ, so my package is apparently on the wrong coast.
And like CA, you can't pass emissions in AZ when the monitors aren't ready, which indeed occurs every time the codes are cleared. No penalty here, you just need to come back later once it's ready.
