kmomma07 »
https://forums.nicoclub.com/kmomma07-u263135.html
Mon Mar 28, 2016 12:28 pm
Hi all, new forum and pathy owner. Recently bought an 01 and have run into an issue im hoping someone else has had. I was told the water pump housing was broken when I bought it, when we changed it we realized it was fine and it was actually the fan clutch. The bearings seized up and so I began the process of tracking down all the parts (PIA), finally got all the parts, got the timing chain lined up (I hope), and everything put back together. When I started the car, it was running really rough, then it was perfect, started it again and it started overheating and my engine light was on. Pulled the codes, multiple misfire, p1140 (has had that code since I bought it.) and p1130. Has anyone else had a similar issue or any idea on what direction I should go? I don't want to start replacing every sensor or whatever if I don't have to.
Rogue One on Mon Mar 28, 2016 6:16 pm, edited 1 time in total.
Reason: Revised title
