Are you talking about a member on NPORA? I think I read what you're talking about a while ago. Do you have a link to the post or do you know why, specifically, he switch back to stock? Did the fans not pull enough air to keep the car at normal operating temperature?SnowSurfLax wrote:The one guy I know of who did it (not on this board) didn't like the outcome at all and went back to a stock fan as it worked better. He's a mod on other boards, so no worries about it being some amateur, he's often asked such technical questions as he's just about done it all.
As far as I know, no variable speed fans out there for a custom application like that. I think it's on or off.
Your fans turn on randomly when the car is off? You don't have them to only be powered when the vehicle is running? That would be weird if I were standing by a vehicle and the fans just randomly turned on, I would be pretty freaked out. So your fans stay on for a little while after you turn off your car?fastpathy35 wrote:ok just in case you dont read my post, the only time it overheated was when i had only one fan and i was sitting in dead traffic with the a/c on. so i bought a 10" also. not a problem since. i would highly recommend the electronic thermostat. it took me some time to find one but you dont have to manually turn them on like a lot of people who cheaply do the mod. the only aggrivating thing is people will ask whos car is running out in the parking lot or why did the car just turn on, as the fans turn off and on until the radiator cools off. it doesnt kill the battery and it doesnt dim the headlights or anything when they kick on. everything put together cost about $120. for the wiring, two fans and the electric thermostat. took maybe an hour to finish it all. wasnt hard at all.
Here is the bare Rad i measured and it was 19 7/8" x 28 1/4"Pwnin O’Brien wrote:
I have a somewhat weird question for ya, do you know the dimensions of the finned area of the radiator? I'm looking to do the electric fan conversion and I don't know the radiator dimensions and the max size fans I could mount to it.[/QUhttp://images.zeroforum.com/new/1/post.gif
Yeah, I have a 3.5...W O T wrote:Youve got a 3.5 right Pownin?
Ive got 4 electric 12" fans sitting in my garage right now, and getting rid of that big a** fan would be pretty cool.
Im curious if the stock fan can be removed completely like that, any idea how it disconnects?
Pretty close to free horsepoweRRRR
Ok, this may be a bit long and boring...slickroger wrote:I'm sorry this may be dumb but I don't understand the reasons for doing this conversion.
Is the truck not better with the fan running all the time so its definitely cool?
and for all the Temps you stated it now seems you want the fans too cool it down when the engine temp is a little higher than the spec temp, is that not worse for the engine?
Just confused educate me so I can consider doing this mod aswell
If you aren't gonna use a shroud with your fans then you have to worry about the surface area of the fans. The factory fan probably pulls somewhere in the neighborhood of 3000 CFM's, but since it uses a shroud it's able to evenly distribute the 3000 CFM's over the entire radiator. When you surface mount the fans, you can get hotspots if you don't cover all of the vertical races with the fan.W O T wrote:I dont think you need to worry about how much area the fans take up on thesurface of the rad, just match or exceed the cfm's of the stocker.
How are you planning on getting the fans to turn on and off?
Ive got an electric in my Crx on a 1/2 size rad, but it simply turns on when the car is on, you seem to want it to work properly
Thats what I don't get. If your converting to electric why not have the fan on when the car is on like WOT said, would that not be the best setup for efficient cooling, and the power wouldn't matter because the alternator is running?W O T wrote:How are you planning on getting the fans to turn on and off?
Having the fans always on is definitely an option, but this can cause your cooling system temperature to fluctuate wildly. This is not necessarily a good thing. When you start your car in the morning and when you're driving on the highway, your fan usually does not need to operate. If the fan is running, it may cool the coolant below the normal operating temperature which will cause your vehicle to run improperly (and likely cause the MIL to illuminate).slickroger wrote:
fastpathy35 says his turns on when the car is off why would you need that. I mean cant the car only get cooler when its off does it really need the fans help when not running?
Now depending on the size of fans you choose are you going to custom make a shroud for them is that easy? or is there somewhere you can get those?
Sorry for the questions Thanks for the answers
Naw man you cant "overcool" your coolant, Elec fans arent loud or anything, having them running when the car is on would be enough. Id buy some electrics and mount them on the front as pushers. But im in canada, I could probly run without a fan for the next 6 months its so damn cold up here.Pwnin O’Brien wrote:
Are the mounts through the fins, did you have to squeeze a space through the rad to for every mounting device?Pwnin O’Brien wrote:
yup that was xplorx4. he took it off cause it didnt cool as well as the stock mechanically-driven fan, even if he left the e-fan running 100% of the time.SnowSurfLax wrote:The one guy I know of who did it (not on this board) didn't like the outcome at all and went back to a stock fan as it worked better. He's a mod on other boards, so no worries about it being some amateur, he's often asked such technical questions as he's just about done it all.
