Hmmm ok I'll start with the drive ability problems since that is what is bugging me the most. The car seems to have a slight mind of its own when starting, in warm weather it was great, but now that its cold, sometimes it seems to want to crank for a few seconds before kicking over, but runs fine and smooth once doing so. It also is incapable of going full throttle, the car downshifts and revs, but doesnt go near as fast as it used to, goes very slow thru the rpm band.
It is throwing a P1110 and P1165 and P1130
Recent maintenance involved a brand new radiator, thermostat, hoses. I also removed the upper intake manifold to tighten the power valve screws after reading the sticky in the pathfinder forum about our motors eating those screws. The screws were loose so Im glad I did it, but then I believe it cause those error codes. I also replaced a leaky oil cooler o-ring right above the alternator, but that was straight forward.
Ive also replaced all of the vacuum lines, after reading that clogged vacuum lines was a common problem for the swirl valve errors, but they did not go away. I do have one vacuum line on my engine, that is currently plugged, as it is supposed to go to the bottom of the factory air box, but I have an aftermarket intake system with K&N filter
You can see the line connected to the bottom of the airbox in this picture, and where it connects on the engine, that is the line I had plugged about 3" after it leaves the engine with just a dab of silicone in the hose end.
Dont mind the arrows, they came from someone elses thread
I recently read a thread that the Maxima MAF part number 22680-2Y001 was a direct drop in replacement for the 01 Qx4, and even though mine had no issues, other than a not so smooth idle. I decided to try it out instead of just cleaning my oem sensor, since my the sensor had 110k miles on it. It did not work as planned, the car throws a P0100 on long straight drives and goes into limp mode. SO I think Im going to switch back to the oem sensor and just clean it, that may fix my full throttle aswell perhaps??
Ontop of all those problems, I decided I wanted some gauges to monitor, I had a coolant temperature gauge and an aftermarket fuel pressure gauge from my other car. Both installed after all these problems incured. I wanted to check fuel pressure as the car seems to start better and not crank as long if I prime the system for a few seconds before starting the car, so I figured my pump may be failing, but the gauge shows 40psi at idle, and slightly increases when I rev the engine in park. The coolant temp sensor seems to show my car never gets up to operating temp if Im driving, while driving it stays around the 110* mark, if I let it idle it takes about 30 minutes to get to 160* (mind you im in canada and its very cold) but I thought the temps would be higher.
A few things I feel I need to do are reset the ecu entirely (the only method I know of is disconnecting the battery for 12 hours), possibly change the oil a few times in short intervals to ensure I have perfect clean oil, as you mentionned my oil looking like it had fuel in it. And I suppose put the factory MAF back in.
