Overrev = motor death
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Did you rebuild the bottom end when you put the pistons and rods in (i.e. new rod and main bearings)? I'm betting you'll be able to regrind the rod journals, buy stepped up bearings, and put it back together again for minimal cost. Did you have any type of oil restrictors in the block?
gawdzilla
Car: none
Darius wrote:Did you rebuild the bottom end when you put the pistons and rods in (i.e. new rod and main bearings)? I'm betting you'll be able to regrind the rod journals, buy stepped up bearings, and put it back together again for minimal cost. Did you have any type of oil restrictors in the block?
everything was rebuilt. used stock rods w/ arp fasteners. all nismo main and rod bearings. no oil restrictors, stock oil pump, good crank collar.
hopefully i can keep the costs down with a crank turn, new bearings, maybe new rod bolts and rods.
if i do rebuild it i'm going to get the oil restrictors and the pump. now that RBs are the new SR, will be much easier to get these parts than my first time around..
Phat_Optimo
Car: 93 S13 SE
Sup BUD.. Long time no speak. Damn bad news man........Hard to tell without seeing the carnage. But it sounds like your oil system fuked up. Lots of heat and friction + no oil = fuked rod journals bearings ect. Hey if u pull it and want your crank reworked we can do it. We can make a stroker out of it and hard chrome the journals. Harder to spin a chromed journal. On my 26 we are planning loose oil clearances (1 big) and a big oil pump. Meh shortblock should be complete soon. BTW e-mail me if you decide to part it out. I'd like to scope the carnage. TTYL
gawdzilla
Car: none
Phat_Optimo wrote:Sup BUD.. Long time no speak. Damn bad news man........Hard to tell without seeing the carnage. But it sounds like your oil system fuked up. Lots of heat and friction + no oil = fuked rod journals bearings ect. Hey if u pull it and want your crank reworked we can do it. We can make a stroker out of it and hard chrome the journals. Harder to spin a chromed journal. On my 26 we are planning loose oil clearances (1 big) and a big oil pump. Meh shortblock should be complete soon. BTW e-mail me if you decide to part it out. I'd like to scope the carnage. TTYL
damn dude, you back from the grave? haven't seen you online in a minute... been through a car and a motor since we last talked haha... i sent you a mail to your gmail account. get online some time
gawdzilla
Car: none
okay... so i take off the main girdle yesterday. see no damage at all.
take off the rod caps, nothing.
all the journals look fine, all the bearings look like they are used but nothing out of the ordinary.
leaked it down before i did anything to the bottom. all cyls fine holding good air w/ minimal leak.
pulled the pan, nothing in the pan.
wtf is going on
Shocker
Car: 89 240sxHB rb26/30
stuck lifter?, my car scared the **** outta me yesterday.. started her up... granted its getting much colder here.. I hear a slight tapping.. sounds like low oil tap from lifters... check oil lvl is fine... I listen very very closely, comming from the back of the block on one side.. give her a slight rev, still there... one more.. gone... The whole time I was thinking I had a bent valve.. turns out it was nothing.... maybe same for you?
gawdzilla
Car: none
it was definitely a loud clacking rotational noise, not a valve tick type noise. also, mine is solid lifter...
Carl H
cracked ringlands?loose wrist pin?i dunno man, what did it sound like when it happened?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Timming belt skip a tooth? Tensioner went to hell?
gawdzilla
Car: none
sounded like this, and i'm not being biased towards the sound... (taken off someone on SAU).
http://smg.photobucket.com/alb...g.flv
TB tensioner, cracked ringlands, etc. would make me lose compression either through a bent valve or crazy blowby. i'm not getting those...
i highly doubt its a bent rod clacking off my cylinder wall just cuz the 26 rods are supposed to be beefy
Darius
That video link sounded like fingernails on a chalk board to me especially when he revved it a little. ugh.
Did you pull the pistons/rods to see if there is damage from interference or something breaking off in a cylinder?? It is hard to imagine that there is no damage to the bearings, leakdown is minimal, and you still have a loud knock like that. You could probably still get good leakdown numbers if the top ring land broke and the second ring was still in tact, but I still don't see that happening easily with forged pistons.
gawdzilla
Car: none
i have no clue. did i blow the trans???
i could still put the car into every gear, but only drove it in 1st. the gear i missed was 3rd, and i never drove it again in 3rd to make sure it was still ok. still with a blown trans i'm not sure how it would make that kind of a noise
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
has to be the motor. Never heard a transmission sound like that. Normally grinding or a loud whining noise. Never a clank. man that same thing happened to me after my belt slipped a tooth. I drove it around like that for months till i found out wtf it was. Fixed it and the noise went away. My idler pulley was the culperate. It siezed and broke the bolt that holds it. Fix all of it and noise went away.
Carl H
sounds nasty, did you open to oil pump to see if something in there got damaged?perhaps a cam snapped under one of the cam caps?
gawdzilla
Car: none
ok... i finally got around to draining my trans fluid today cuz the drain bolt was stuck. at the time i figured F it just let it drain slowly as i lift it out of the car.
break the drain bolt loose and ... it is about twice the size as it was. big *** metal chunks stuck to the magnetic end of the drain plug. what a relief, blew the 3rd gear. i put the trans in neutral and rotate the input shaft by hand and feel it binding. same with 3rd gear.
i'm gonna get some arp moly and assembly lube and retorque my mains/rods. good thing i didnt go too far with the disassembly.
while i'm down there i'm going to get an n1 oil pump just in case and get some cams hopefully.
who would have known that a loud clak clak clak noise could be the trans?? lesson learned, right now i'm just relieved its not some mystery anymore and my motor is ok. i guess its time to shop for a new trans.
Carl H
whoops.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
yha that beats internal work
Carl H
the odd thing is that he had a 'new' r34 rb25 gear box, that thing should have held power.just goes to show that its not the power that kills the box but the torque applied, doing full throttle shifts shocks the box from all the torque...that being said my rb20 box has held up fine and shifts perfectly but i dont full throttle shift and slip the clutch when launching it.
300Plus
Car: 1995 S14 w/ Rb25det Series II
So were you able to crank the motor and prove it was just the transmission or are you just hopping its just the transmission and not both ? Hope for the best! keep us posted
