sleeper07 wrote:I got it checked from a shop... they said it was the head gasket... but i dont think it is if it dosent over heat without thermostat i dont know what too do anymore
If the coolant system is not losing coolant, then the head gasket is most likely OK. You can verify this further by doing a compression test on all cylinders.
If it doesn't overheat without a thermostat, then it's probably a thermostat issue. If you're using an aftermarket thermostat, it'll cause more problems. Buy a new OEM thermostat from a Nissan dealer.
As a side note; when you run without a thermostat, the ECU will sense a low operating coolant temperature so it will richen the fuel fixture. This will cause the MPG to go down the toilet.
