matt4pl »
https://forums.nicoclub.com/matt4pl-u4587.html
Wed Sep 19, 2007 5:32 pm
you can test the temp sensor with a multimeter but usually the sensor gets coated with mineral deposits making it read colder. usually. zoom's case is the 1st ive heard of having it read a high temp, but that i guess could be internal shorting. you'd need a temp gun or probe or some way to verify the actual temp though. its a NTC type thermistor so resistance goes down with an increase in temperature.
also, the sensor reads coolant temperature, not physical engine temperature. running without a thermostat will give you a false idea of whats going on. think about this: notice how the actual area of the thermostat that opens is much smaller then the overall diameter of the tube it fits into. reason being is the thermostat, even when fully opened, creates a restriction to flow specific to the engine to keep it at its proper operating temp. look at any thermostat from any car and they're all made that way. its kinda like sticking ur hand in hot water, if its only in there for a second, not a lot of heat energy can transfer from the water to your hand, keep it in there longer and you're gonna get toasted. thing is you don't have a radiator to cool your hand off but thats besides the point.
