Overheating after replacing new engine
Driftin115
I recently dropped in a motor. It overheated and I replaced the thermostat and waterpump. It was fine for a day or so then started overheating again. I think my thermostat is stuck closed again. I am going to replace this again. Does anyone know why this keeps messin up? Any help is appreciated.
mb_s13
Car: 91 Nissan 240sx
You did remove the bleeder screw and bleed the system, right?
Space Monkey
Car: 1990 Nissan 240sx
Sounds like someone has to burp the baby
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Space Monkey wrote:Sounds like someone has to burp the baby
480sx
Car: 1996 Pearl White 240sx
You have air trapped in your system thats not letting the water flow through your motor as it should. All you have to do to avoid this situation is poor your coolant REALLY slow when your filling the rad. I spend 10-15 min poring coolant, and never have any problems. The KA loves to trap air in the coolant system for whatever reason.
Raise the front of the car into the air as high as you can with a floor jack. Open both the bleeder valve and the radiator cap and start the car. Let it run for 5+ min with both of those things off. After 5 or so min when the waters reached near op temps, top off your radiator and wait for a constant stream of coolant to come out of the bleeder port. Cap it off, then let the car idle for a while with the rad still open and the car jacked up in the air. It also helps to rev the motor to 2-3000 rpms to get the coolant flowing.
Spinn3r
Car: 1996 Nissan S14 Zenki T3/T4
480sx wrote:You have air trapped in your system thats not letting the water flow through your motor as it should. All you have to do to avoid this situation is poor your coolant REALLY slow when your filling the rad. I spend 10-15 min poring coolant, and never have any problems. The KA loves to trap air in the coolant system for whatever reason.
^^^ correct.
Driftin115
I did the whole bleeder screw ordeal but I did't wait like you said. We cranked the car, let it run. Poured antifreeze in it till it started coming out, put the radiator cap back on, then took the bleeder screw out, waited a few secs then put it back in.
Also, it runs like crap. When I ease into the gas its fine but when I get on it hard or pin it...it just sucks. It has no power at all. Sometimes it backfires. We moved the distributer over and that helped a little bit. Could it possibly be out of time and this screwing everything else up?
P.S. the motor has been sitting for a while.
powerline
Car: 1993 Nissan 240SX convertible
08 Ford F350 crew dually
2004 Acura TSX 6speed
1997 Nissan truck
2006 Scion XB
have you checked the compression?
chicos240
Car: 1995 240 SX
well wally i think you need to do a compression test and a timing check, though id do the compression first since its easier.
