+1at least that's the symptoms of a bad mafs. Running super rich and stalling at neutral... But usually, bad mafs has a rev limit of 4k, and not 2k..TheOne wrote:prolly wouldn't happen due to overrevvin, but revvin to 2k type limiter and smell of gas usually = bad/disconnected MAFS.
accidental downshift to the wrong gear. no way a rev limiter will stop that.sebazztard wrote:how can you over rev with a limiter? if you smell gas and there is no response, im thinking something came loose? hopefully its something simple.
on an SR MAF it only revs to 2.5k My buddie had the same problem. His maf took a **** on him and it sounds kinda like what yours it doing.adrians_s13 wrote:+1at least that's the symptoms of a bad mafs. Running super rich and stalling at neutral... But usually, bad mafs has a rev limit of 4k, and not 2k..
I'd say try cleaning your mafs sensor with a mafs sensor cleaner and hopefully it was just a coincidence that it happened when you over revved, lol.
i have a z32 MAF. not sure if it works never hooked it up but its yours if you want it. IM me if you want itsbird1 wrote:It sounds better when I unplug the MAF. The smoke is definitely gas. I think the MAF is my problem... anyone have an extra SR or Z32 MAF? I may upgrade since the time seems to be right.
i second that. my car was acting similar to what you decribe and it ended up being a leak in the intake after the maf.spooled240 wrote:check for leaks in your intake and your intercooler pipes. A blown pipe or a leak (even a small one) can make the car run funky and not want to rev.
That was my first thought. I expected to open the hood and have one of my intercooler pipes popped off from too much boost, but alas, I may have to dig deeper. I have a GReddy FMIC, so I expect it to not just develop a leak just boosting 15 psi. Just thinking out loud, I need to check the plugs where I blocked off the stock recirc. So here is my plan:spooled240 wrote:check for leaks in your intake and your intercooler pipes. A blown pipe or a leak (even a small one) can make the car run funky and not want to rev.
