Over-revved my SR...
spooled240
Car: kouki s14
ok that makes a lot of sense, you probably have a boost leak..which is a good thing since it's an easy fix.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Go buy a compression tester. Compression test is always step 1 when you think its something internal of the engine. If thats not it, do the boost leak test. Then check the MAF and Intake Pipe. If all is fine then check for an injector leak by lifting the fuel rail up with the fuel lines connected and prime the pump. When fuel pressure builds, the leaky injector will spray fuel.
inkslingers13
Car: 1985 Corolla Gt-S
urcaptnspeaking wrote:I wouldnt figure 7500 would kill it, but I have been wrong before, that and I dont know the Sr's redline...
lmao, its 7500...
sbird1
Car: 2006 BMW 325i
So I took my valve cover off the other day and everything looked cool. Today I compression checked it and returned with 130's across the board. Then I found that a couple of intercooler couplers were cracking from age and one had popped off the back of one of the pipes. I think my higher boost level (first time running over 15 psi on my new setup) blew all the weak points in my IC system.
Also, today at work, I put new tires on an E 55 AMG then got to take it for a test drive. That thing is one ballsy saloon.
