you should be at around 20 inchs hg vacuum at idle, if you are at zero you have an issue, either the gauge is hooked up improperly or it is failing, at cruising speed I am seeing between 10 to 15 in hg and off throttle in gear I am between 25 and 30. Also, are you using the stock water temp gauge, when I first did my swap it read all the way hot even though the engine was running properly, I discovered that the gauge sender that was on my motor didnt put out the right signal for the stock gauge, try putting the gauge sender from your stock motor onto the new one.90_240sxx wrote:hey guys before you say search i did and it didn't help much. I still cant find the problem and before i give up and take it to a shop i thought ill try here first. So i got an s13 w/an s14 sr20. I got a 2 inch aluminum rad w/2 10 inch fans and a new water pump. I all ready checked for leaks and didn't find any and i have bleed the system. Also i checked if the water was running good and it is checked for smoke to see if it was the head gasket and nothing. If my boost/vac gauge is at 0 when idleing and around -12 when cruising at any speed could that cause my overheating issue. If so what can i do to fix it. oh and i all ready took the thermo out because i thought that it would be the problem thanks for any help given
when i first start the car the gauge reads optimal but close to lean then as the car worms up the needle goes down all the way down to lean and it stays therehpmachine wrote:does your a/f gauge read dead lean even while driving? If it's running way lean all the time, that could cause it to overheat. I think when a o2 sensor goes bad, it causes the car to run rich.
at cruising speed I am around -12 or -14 and off throttle in gear it goes back to 0. it only creates vac when im in throttle and yes it does make boost as well when i step on it . and no its not the gauge the water does get hot boiling hot.SideWays=smiles wrote:
First off you have vacuum leaks and that is why your reading 0 at idle. Get that fixed.90_240sxx wrote:
thanks but i cant use it since there talking about a ka24 ecu and my s14 sr dont got a nob or lights in the back of it. but i think you were right if the 02 censor goes bad i think it does make it run rich because my old ka had a bad connection on the 02 and it made it run rich. oooh i got an idea im gonna disconnect the 02 censor and see if it runs rich if it does it might stop the over heating since it wont be running lean any more. but if it does work that means i got some fuel issue that i got to take care ofhpmachine wrote:this might helphttp://forums.nicoclub.com/zerothread?id=190023
