haha I only say that adrian cause it helps me cope with the fact that my poor a$$ can't afford themadrians_s13 wrote:anyways, get coilovers, they aren't as bad as everyone hypes them up to be. If youre worried about comfort, look for a spring rate of like 7/5 or somewhere close to that.
duuude... every now and then I see people part out dope asss cars for whatever reason... I've seen used coils sell for like $400. If theyre not blown... why not? my buddy got a set of some jdm tyte Cusco Coilovers for $500 used at some shop here in socal, my cousin picked up a set of JIC coils for like 550, and I got my HKS hypermax II's for like $600 with like 10k miles on them... you just gotta be on the lookout, lolx240xdrifter wrote:
I frequent through Spartanburg to Greenville like once a month.240DRifter7 wrote:YO! your in RockHill.Im in Spartanburg man..
Theres a city named "Spartanburg?" SCHWEET!!240DRifter7 wrote:Im in Spartanburg man..
wait... you have a fmic, but no turbo?? interfooler...Tr0uble wrote:Current Mods on Car:
S15 Silvia Front End conversion (S15 Oem Bumper, modified S15 Oem Steel Fenders, Seibon Oem S15 CF hood, S15 Core Radiator Support, S15 Silvia non-HID Headlights [oem HID=$2,200 )zerothread?id=231901
Koyo RadiatorDual 12 or 14in? Slim Flex-a-lite Fans180sx Type X Rear TaillightsYellow Top Optima BatteryShaved Door Handle Electromagnetic Solenoid w/popperCustom 3 inch stainless still piping with Apexi N1 MufflerBlitz Intake
Near Future plans: (No particular order)S14 Sr20DeT Swap with T28 TurboNismo Power Front Brace Welded to Core SupportTein Coilovers? (plans for car is street/show)Paint Job
Distant Future:Kaaz LSDCustom Sparco Seats (sparcostiched.com)Tanabe 4pt HarnessRedo Interior (tips on interior needed) - Broadfield Front lip, Side Skirts, Rear Bumper, Carbon Fiber Doors, Valances
Well it's just that back when I owned a EG I had bad experiences with coilovers car would bounce and almost lose control cuz the dampers werent adjustable I guess. Just wanted to get some opinions going before I throw $600-$1200 at a suspension setup.VW Acolyte wrote:i dotn know about 240's so much but i have been on Bilstien PSS coils on my jetta for like thre years now. 2 in the first jetta and about a year and a half in the VR6. i drive it everyday with no problem. they actually feel a bit soft to me now, tho everybody i know says they feel stiff to them, lol. i cant adjust the shock stiffness on mine (thos are the PSS9's), but if you get a set that you can, they will be just fine for daily street driving. you will get used to they very quickly. i mean, if i can drive everyday with coils on florida roads (which are all underconstruction ), you should be ok.
Yea I ordered all the parts for the swap before the motor. Intercooler was only on car for 1 day so I could check alignment of lower part of s15 core support. Also I went ahead and trimmed the parts of the bumper that's touching the intercooler so I can fit the mesh on when it gets here.I also finally welded the lower portion of the core support on seeing as how the intercooler fit pretty nice.I'm either going to have to do some custom piping when I drop in the S14 motor or cut a big circle in the frame rail to run the piping. S14/S15 piping normally runs thru a hole in the frame rail on the S14/S15 chasis which doesn't exist on the 240sx/s13 chasis.adrians_s13 wrote:
anyways... with all that visual upgrading... you better get some coilovers... if you don't
well first off, what kind of coils did you have? also, civics are pretty light, too stiff of a coil will make a light car bouce crazy. plus, like what was said before, you have to watch your spring rates.Tr0uble wrote:
Was at Petlovers weekend before last until the cops ran us off then we all went to Freeman's. I don't hang around rock hill much though. I'm either at my house working on the car, at work, or in Charlotte.MustangManV6 wrote:I am in Rock Hill also, never seen you around
Was Skunk2 on the EG. If I jacked the car up there was about 4-5 inches of vertical play between top of the strut tower and the spring. I just didn't like hitting a bump and the car go flying off the springs. Especially that bump on I-485 eastbound when you cross over that over pass after you pass the mall.I'm a big fan of real tight suspensions like when you push down on the car it doesn't move much, and when you jack the car up the wheels only move like an inch or 2 from when there was weight on it.VW Acolyte wrote:well first off, what kind of coils did you have? also, civics are pretty light, too stiff of a coil will make a light car bouce crazy. plus, like what was said before, you have to watch your spring rates.
Think I'm going with theseKsport Kontrol Pro Fully Adjustable Coiloverhttp://intensepower.com/kskoprofuadc.htmlboznuttz wrote:Koni's FTW!
ah, ok. you had those type of coils i hate. the ones i have are threaded body shocks or struts. the spring stays seated for the most part.Tr0uble wrote:Was Skunk2 on the EG. If I jacked the car up there was about 4-5 inches of vertical play between top of the strut tower and the spring. I just didn't like hitting a bump and the car go flying off the springs. Especially that bump on I-485 eastbound when you cross over that over pass after you pass the mall.I'm a big fan of real tight suspensions like when you push down on the car it doesn't move much, and when you jack the car up the wheels only move like an inch or 2 from when there was weight on it.
Are you going out there this weekend? I have a few friends from Winthrop who go out there. I will be in the Stang thoughTr0uble wrote:Was at Petlovers weekend before last until the cops ran us off then we all went to Freeman's. I don't hang around rock hill much though. I'm either at my house working on the car, at work, or in Charlotte.
Now we start the count down until they blow *knock on wood*Tr0uble wrote:Ordered the Ksport Kontrol coilovers
