ok yea i understand the continunity test thing but if both plugs are plugged in where should i test the postive side at? should i shredd a little piece of the wire and test it there?..also i was jus on 240sxmotoring looking for the ecu pinouts to find the ecu ground. I found the different ecu's that match up to the motor sets and it listed this:
E5 is from a 94-96 180sx black top 5 speed
E6 is from a 94-96 180sx blacktop automatic
WC is from a 94-98 S14 Silvia
62 is from a 91-93 180sx or S13 Silvia 5 speed
61,63 is from a 91-93 180sx or S13 Silvia automatic
J4 is from a 97-98 180sx Type X 5speed
now if u look in my other thread
zer...age=2 my motor is a 93 on the chart is says to use a 62 ecu for a 91-93 and a e5 for 94-96 i have a e5 do you think thats the problem?
