okay, time to make some performance mods
All things Altima Coupe.
incREDibL3
Car: Nissan Altima Coupe
well im trying to FINALLY get some mods going for my car (8 months later) .
but i need some help from you guys, what should i get first ?
Greddy Exhaust SE Sprectrum or Megan Coilovers. I have about $1000 saved up, trying to see whats the best thing to do.
Unless someone can find me a good prices for both. :biggrin:
AlexM.
Car: 2010 Nissan Altima Coupe 2.5 Super Black
Do you want speed or do you want to handle well first? Or both?'
For speed, I'd do a bullydog tuner
Suspension - coils
Both on a budget - tuner and springs.
Nlghtmare
Car: 2008 Altima Coupe 2.5
AlexM. wrote:Do you want speed or do you want to handle well first? Or both?'
Suspension - coils
Agreed.
If you have a 2.5 get the header after. Intake and exhaust at the same time. I suggest doing springs FIRST. I should have. I regret not doing it.
Kingd1987
Car: 2010 Altima Coupe 3.5SR
Whats up, this is my first time on a forum. just bought the 2010 3.5SR coupe. looking for the cheapest way to go for coilovers any suggestions? i already bought the eibach lowering springs and had them installed but im not very happy with 2" drop.
Nlghtmare
Kingd1987 wrote:Whats up, this is my first time on a forum. just bought the 2010 3.5SR coupe. looking for the cheapest way to go for coilovers any suggestions? i already bought the eibach lowering springs and had them installed but im not very happy with 2" drop.
Really? More or less?
incREDibL3
I already lowered my car on eibach springs. Like it but i want moree.. but at the same time i want my exhaust. Lol what does the bullydog tuner do?
downedzephyr
Car: 09 Altima Coupe 3.5se
Suspension - coils
I disagree. If we're talking bang for the buck performance and OP has about $1k saved up, I say get a y-pipe, rsb and fsb, on the assumption OP has a 3.5.
the y-pipe is cheaper than the bullydog and you still see 10-15hp in gains, while the rsb/fsb/spring setup will make the car handle way better.
$265 (racingline ypipe) + $150 (racingline rsb) + $110 (racingline fsb) = $525 + shipping. Then go get a magnaflow setup with the remaining money and you're golden.
RicerX
Car: '20 Titan Pro4X
Rock the Eibachs for a while. Go with this stuff if you're a 3.5. Throw in the Racingline STS if you have a 6MT. If you want the total package, add a Stillen Axle-back to get a better look and overall exhaust flow. The y-pipe is the weakest part in the exhaust for the 3.5s. (Header is weak link in the 2.5s). The rear section of the exhaust is HEAVY. A Tanabe Medalion axle back saves 10 pounds (and looks EXPONENTIALLY BETTER than the terrible looking OEM exhaust). Stillen Axle-back for a budget. It will also save weight, though I'm not sure how much.
What sucks about our cars is the catbacks are terrible for true performance increase. Both Greddy catbacks (TiC and SE) are only 60mm piping (2.3 inches-ish), and the Nismo has variable piping diameter, sometimes as low as 1.8". N/A VQs see gains on piping diameters as large as 3". The stock muffler section is also restrictive, so that's about as good as you can get. At one point, a guy from stillen said that there was only a 1-2hp difference between the axleback and catback systems.
I'm debating a custom single exhaust for mine with a universal muffler of some type. Have not decided yet.
trigger_storey
Id say there are plenty of exhaust out there that are just as nice and cheaper then spending the money on the Greddy. Buy a different exhaust and put the money toward something else like the racingline y pipe or intake.
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
i like the greddy exhaust look & sound but the price is the main reason why i went custom. for a custom exhaust, it will come out more than half cheaper than the greddy. if your trying to save money, go custom and youll have money left over to continue to mod.
thisisjun
Axel.. you already know i can hook you up with prices =]
dom_cull
Car: altima coupe 2.5s
how much are megan coils?
AlexM.
That's a pretty good combo. :dblthumb: Is the rsb+fsb handling > coilover handling you would say? Even if it isn't, 525 is great for that extra power and better handling. Idk how much of the power you feel from the y pipe but Ive heard you really feel the difference with the tuner. Maybe I'd go with tuner + rsb + fsb since you already have the drop
downedzephyr
i don't have a ypipe or fsb, so i really couldn't tell you. this is what i've heard from other people, namely local coupes, that have those parts. i would imagine that it would help with the body roll, and that is a definite improvement on handling. the fsb is next on my list though, to pair with my coils and rsb.
and btw you quoted it wrong lol
AlexM.
Lol my bad. If fsb = front strut bar dont get it for performance cause I don't feel a difference and I have a rear sway bar (stillen)
incREDibL3
i would get all that but to bad i have a 2.5, i dont have a 3.5, so what can i get with a 2.5?
downedzephyr
incREDibL3 wrote:i would get all that but to bad i have a 2.5, i dont have a 3.5, so what can i get with a 2.5?
best bang for the buck mod for a 2.5 has got to be the headers. so instead of a ypipe, get headers + rsb + fsb.
thisisjun
get coilovers man. rob and i've been telling you that man! low is the way to go
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
Do in the following order for engine performance: (My opinion only)
1. Intake
2. Exhaust
3. Header
4. BD Power Pup / GT Tuner, you should be able to find the Power Pup for cheap now since the GT Tuner replaced it.
For suspension stuff I agree with the previous posts except for the front strut bar. It won't do too much. Get the rear sway, end links etc. If you are lowered on wider/larger wheels I would suggest the Eibach Camber kit for the rear as it's super cheap and will correct any camber wear if you have any. An alignment will not fix this issue.
Other things you can look at besides "performance" mods, although, the mods below offer visual and look performance I guess haha:
1. 4300K - 6000K HIDs for best light output. 4300K will look factory, while 6000K will be near pure white. Anything above will be blue to purplish unless that is the look you are going for. Keep in mind the higher temperature you go, the less usable light you have.
2. Body components such as:
- Spoilers
- Carbon Fiber Hoods
- Front Fascias / Grilles
- Fog Lights (if you do not have factory ones)
Just to name a few.
3. Stereo system / Navigation. Speaker replacement if required (I'm still running stock non-bose and they sound ok for me).
downedzephyr
QR25DE wrote:If you are lowered on wider/larger wheels I would suggest the Eibach Camber kit for the rear as it's super cheap and will correct any camber wear if you have any. An alignment will not fix this issue.
you could actually just get a set of adjustable camber arms for a 350z, from another thread that i read on here the part number for the OEM camber arm on the a/c is actually the same as a Z. sure the bolt is cheaper, but it's sooooo much easier to just swap the entire arm instead of having to do some drilling. and i've actually heard that the endlinks are a waste of money as well.
I also agree that HID's are a good investment, both cosmetically and performance-wise (on the assumption you don't get some rediculous color like 11k and something more usable, like 5k or 6k).
QR25DE
Oh right, yeah I saw that thread. Good memory!
Oh, and this is good for 40HP... installing-red-gtr-start-button-t521999.html
Might consider doing that lol.
downedzephyr
haha win! i would change that part, but i'm lazy. plus i figure i'd be too tempted to keep pushing the big red button.
QR25DE
Hahahaaha
Ranga14
Car: Boosted 08 Altima Coupe 3.5
I'd go with a cheaper engine mod like intake or bd tuner and the rest of the money spend on sway bar+drop and maybe one asthetic mod if you have any money left over like a Stillen lip. It does wonders for the looks of the front of the car.
incREDibL3
QR25DE wrote:Do in the following order for engine performance: (My opinion only)
1. Intake
2. Exhaust
3. Header
- Spoilers
Just to name a few.
that helps alot! but thx everyone for the help, now i have an idea !ill keep you guys in touch for any new mods i do.
wish i can do carbon fiber hood, i have 2010 model! sucks ! lol
elfenlied8
Car: Altima Coupe 2010 2.5S
stickers +50hp!!!
