and i also know survey's are so often skewed that its not even funny.takeshi wrote:It's a survey. It is what is is. You can disagree with it but unless you've done a survey with a statistically significant sample an individual opinion really doesn't mean anything.
its not unreasonable. i work with cars, and DO think nissan is leaps and bounds ahead of many manufacturers. talk to a mechanic, before you make assumptions the car you own is below dodge/chrysler/buick/mazda/lincoln/ram/suzuki/chevy/ford/bmw/gmc, etcTrevorK wrote:But to think that Nissan is leaps and bounds ahead (or behind) any of the major car makers definitely seems unreasonable.
that post was said better than i ever could.kerrton wrote:I'd take your Rogue with its 4 problems related to minor things like the hatch struts, over a Dodge Journey which has only 2 problems, transmission failure, driveshaft and transfer case failure (common problems with early Dodge Journey's). Would you say the Dodge is more reliable because it only had 2 problems and the Nissan had 4?
I honestly believe that owners of high quality vehicles like Toyota, Honda and Nissan over-report defects because all the major stuff is so good (i.e. powertrain, electronics), they have higher standards than a Dodge owner and look for small things to complain about
That's your opinion and you're entitled to it.ImStricken wrote:its not unreasonable. i work with cars, and DO think nissan is leaps and bounds ahead of many manufacturers. talk to a mechanic, before you make assumptions the car you own is below dodge/chrysler/buick/mazda/lincoln/ram/suzuki/chevy/ford/bmw/gmc, etcTrevorK wrote:But to think that Nissan is leaps and bounds ahead (or behind) any of the major car makers definitely seems unreasonable.
That's the exact reasoning that shows the potential flaw in the reports - the amount of data and the interpretation of the collected information that results in the collected data. With such a small sample of data it's possible to achieve an extreme (many part replacements, few part replacements) either way. I think it's reasonable to say that, if you were a courier for instance and drove 400 miles/day on the highway that the results of your vehicle would be much more positive than someone who drove stop and go every day in heavy traffic. This is why you need to sample a large number of vehicles, your driving habits and even your ability may be drastically different than those around you. It could even be as simple as some people perform less maintenance than you do, hence encounter more problems.ImStricken wrote:how many people you know can say they replaced, at most, 2 parts- on a car between 0 - 150,000 mile average? the only people i know who can say that = are nissan & honda owners. (honda makes an amazing car, but they use a rubber timing belt = which costs a TON of money to replace every 60-80k which is why i stay away form those cars)
This is just it. One of my problems is my hatch struts and is no where near as serious as a CVT transmission failing. Yet they may both be on the same level when it comes to this report.kerrton wrote:Trevor I think you're hinting around the idea that just a total number of "problems" may not be the best way to determine quality and reliability without considering the magnitude of the problem.
I'm not trying to pick a fight but would you agree there are many people who would say the same thing about Nissan and their early CVT transmissions? I think it's very reasonable to think that there are many customers that would not buy a Nissan again after their CVT failing. We're talking about an entire brand here and picking out a single model, especially a newly designed one, that experiences significantly more problems than expected can be done with any brand.Of course not, the Nissan powertrain is tough and will last you 200,000 miles before having issues, whereas the Dodge had major powertrain failure early in the vehicles life, and will likely have repeated powertrain failures until someone finally gets fed up and parks it at the auto wreckers before it even hits 60,000 miles.
This all goes back to the stats being misleading. I am sure than many owners would have just lived with the hatch struts and said "well it only happens in the winter". And I'm sure there are many Rogue owners that say the same thing. Perhaps a better judge of quality, or a statistic that may be more valuable, would be an indication of the average amount of warranty work performed over a 3 year period. This would eliminate small problems (like the hatch struts) and really isolate major problems (transmission).The Dodge probably has crap rear hatch struts too but nobody reports it, they're too busy worrying about powertrain failures!
Good points Trevor, I agree. Nissan definately did have CVT problems in the 2003 Murano, and to a lesser extent the 2008 Rogue. I'm not arguing that Nissan is better than Dodge in reality, it was just an example. I was basically saying what you're saying, that those stats are not a real good method for ranking reliablity by manufacturer. Good discussion, thanks.TrevorK wrote:This is just it. One of my problems is my hatch struts and is no where near as serious as a CVT transmission failing. Yet they may both be on the same level when it comes to this report.kerrton wrote:Trevor I think you're hinting around the idea that just a total number of "problems" may not be the best way to determine quality and reliability without considering the magnitude of the problem.
WRONG. not all cars are produced in a similar fashion. have you ever seen the paint on mercedes? as much as i hate mercedes, i have to be 100% and state they have a process unlike any other. the best i would say. have you ever seen the paint on a kia? nissan? toyota? compared to that of a mercedes? totally different paints, painting process, etc. and thats just the tip of the iceberg.They are produced in a similar fashion
WRONG. there are many companies that make a common part. take simple sparkplugs: NGK/BOSCH are the top leading brand. then take Champion which is total crap, that dodge and GM and ford use. NGK/BOSCH last 100,000miles, while champion will last 50-60k. thats just the beginning. some companies use delphi parts, some use differeent brand - which last for longer or shorter durations. i cant believe you thinks that one company makes everyone's alternators, another company makes everyones PSpumps, another company makes everyones cv joints, another company makes everyones bushings, another company makes everyones bearings, etc etc etc etc? i guess you think everyone has the same head units? nissan uses clarion & bose. while infiniti uses not only bose, but pioneer as well."They use parts sourced from a common supplier"
thats so wrong, its not even funny. many companies like say ducati uses a certain type of valve that they patented. some cars use rubber timing belts, while companies like nissan use timing CHAINS(metal). some cars have cvt transmissions, some use 8speed transmissions."No company possesses some sort of technology that is not readily produced by another team"
no offense, but its YOU who is absurd. you honestly think that 1 manufacturer is the same as the other? have you ever realized why certain car-makers have better or worse resale values then others? its not due to design - its due to quality. take toyota/nissan/honda for instance... do you realize why they hold resale value that is higher than say kia/ford/dodge/etc? take a long hard thought and hopefully you come to a conclusion."to think that mechanically a brand is better than another where in this day and age we precisely engineer and manufacture products is absurd."
make no doubt about it - honda makes a better car than nissan; this coming from a nissan gear head. they just do. they use higher quality parts, their manufacturing process has higher standards, and the cars last long because of it. BUT they use timing belts, rather than timing chains = so i stay away from it. toyota has had serious recalls in the past few years... if you were correct at assuming "They use parts sourced from a common supplier" then everyone would have common recalls and issues. but obviously your wrong.I'm all for a discussion on the quality of vehicles but you're going to need to show why you think Nissan engineering is superior to Toyota, Ford, GM, etc.
If i sat here and took apart every manufacturers cars and why they suck or are better than others - id be sitting for 6 hours. the market dictates the truth. there is a reason why american garbage almost flopped and wiped itself out. people caught on and stopped buying the garbage being produced by the big 3 (ford/Chrysler/GM)It's easy to pick on general points (like problems with new models for instance) but we're talking about an entire brand here and it seems unlikely that any, in this day and age, possess some sort of magical engineering that makes them better.
Hatch struts, damaged rubber molding on delivery (although to be fair this may have been caused by the dealer even though they said "it came this way" however it was repaired under warranty), front bumper was cut improperly from the factory (leaving unsightly lines that don't match) and peeling paint. The bill for all the work so far is well over $2000.ImStricken wrote:kerrton wrote:PS: Trev, what were you 4 issues, btw?
Sorry - for some reason I thought you had a bad experience with a Journeykerrton wrote:Good points Trevor, I agree. Nissan definately did have CVT problems in the 2003 Murano, and to a lesser extent the 2008 Rogue. I'm not arguing that Nissan is better than Dodge in reality, it was just an example. I was basically saying what you're saying, that those stats are not a real good method for ranking reliablity by manufacturer. Good discussion, thanks.
It's too narrow, focusing on one model year. So what if a particular brand has a problem that year with gas pedals getting stuck (Toyota), or spontaneous combustion (Ford)? Does that impact the current model in any way?ImStricken wrote:http://autos.yahoo.com/blogs/motoramic/ ... 44256.html
(Just to keep the thread clean I snipped most of your post out, not to be rude)kerrton wrote:And so within all of these painful details, you will see HUGE variability from one car company to the next. Lots of "similarities" too, yes, but many small differnences that translate into big differences by the time the final product reaches us consumers, even if we don't have the ability to notice the differences.
Have they? Do they? What data are we using to show they have the "best process" in recent years? Certainly it can't be sales because Honda isn't that high and GM fights with Toyota for top sales. I'm not trying to start a fight what sort of data is there from recent times to support this?Toyota and Honda have been known to have the best process in place for years to achieve the balance I described above, and keep customers happy with good value.
Not meaning to be rude, but the opinion of someone who has owned a handful of Nissan product and put 150K miles on each of them isn't a valid sample. While it may show what he can expect from a vehicle he owns (as in, what he should expect his next vehicle purchase to be like provided the variables he adds to it are the same) it is not representative of what a typical driver can expect.I take ImStricken's opinion seriously, he clearly stated that its based on imperical evidence - data that he's gathered first-hand over the years by phycically working on these vehicles, observing wear patterns, signs of quality parts etc. I'm not saying he has the final word on the subject, just that what he reports discovering is a valid piece of information.
Fine, let me qualify (which I didn't think I need to).ImStricken wrote:WRONG. not all cars are produced in a similar fashion. have you ever seen the paint on mercedes? as much as i hate mercedes, i have to be 100% and state they have a process unlike any other. the best i would say. have you ever seen the paint on a kia? nissan? toyota? compared to that of a mercedes? totally different paints, painting process, etc. and thats just the tip of the iceberg.They are produced in a similar fashion
[/quote]WRONG. there are many companies that make a common part. take simple sparkplugs: NGK/BOSCH are the top leading brand. then take Champion which is total crap, that dodge and GM and ford use. NGK/BOSCH last 100,000miles, while champion will last 50-60k. thats just the beginning. some companies use delphi parts, some use differeent brand - which last for longer or shorter durations. i cant believe you thinks that one company makes everyone's alternators, another company makes everyones PSpumps, another company makes everyones cv joints, another company makes everyones bushings, another company makes everyones bearings, etc etc etc etc? i guess you think everyone has the same head units? nissan uses clarion & bose. while infiniti uses not only bose, but pioneer as well."They use parts sourced from a common supplier"
Do you seriously think that no other company could design that sort of technology if they wanted? Come on, let's be realistic.thats so wrong, its not even funny. many companies like say ducati uses a certain type of valve that they patented. some cars use rubber timing belts, while companies like nissan use timing CHAINS(metal). some cars have cvt transmissions, some use 8speed transmissions."No company possesses some sort of technology that is not readily produced by another team"
heck, the GTR has one of the craziest AWD designs of them all.
Honestly, I'm just going to come out and say it. No, it's not me, it's you. You clearly feel strongly about your points where you indicate "WRONG" in big letters yet within seconds I can provide you with links to credible information that supports my point. Where is your credible information?no offense, but its YOU who is absurd. you honestly think that 1 manufacturer is the same as the other? have you ever realized why certain car-makers have better or worse resale values then others? its not due to design - its due to quality. take toyota/nissan/honda for instance... do you realize why they hold resale value that is higher than say kia/ford/dodge/etc? take a long hard thought and hopefully you come to a conclusion."to think that mechanically a brand is better than another where in this day and age we precisely engineer and manufacture products is absurd."
[/quote]make no doubt about it - honda makes a better car than nissan; this coming from a nissan gear head. they just do. they use higher quality parts, their manufacturing process has higher standards, and the cars last long because of it. BUT they use timing belts, rather than timing chains = so i stay away from it. toyota has had serious recalls in the past few years... if you were correct at assuming "They use parts sourced from a common supplier" then everyone would have common recalls and issues. but obviously your wrong.I'm all for a discussion on the quality of vehicles but you're going to need to show why you think Nissan engineering is superior to Toyota, Ford, GM, etc.
And this is exactly what I'm having a really hard time with; it is obvious that auto manufacturers use many of (obviously not all) the same supplier for parts. What can set them apart (in terms of quality, we're obviously not dealing with appearance) is the process around putting the vehicle together, testing it out, engineering behind the product, etc.kerrton wrote:This is a good discussion. Trevor, one thing I just want to rehash that we are disagreeing on: the fine details ARE important, they're critically important to this entire debate! The fine details in design and manufacturing are what sets apart the good from the bad, and good from the best. Yes all are similar, but its the fine details that are critical to success. Your argument is to ignore the fine details, and state that "they're all very similar and very close in quality". They may be close in quality, but some are better than others, that's what we're discussing,
I'm not trying to attack you but it has to be said, all brands have some form of brand loyalty. Are there not Nissan fans? Toyota fans? Honda fans? GM fans? They all have their own fanbase that, for whatever reason, will look towards a specific brand of car first before considering anything else. That's hardly a reason to suggest the big 3 do well.I think one of the only things that has kept the Big 3 going is brand loyalty, and lucritive fleet vehicle deals. I work for a Government Agency in Canada with a large fleet of vehicles and we are only given Big 3 vehicles as options, no Toyota, Honda or Nissan etc..
thats all fine and dandy, but like the example i have made above: JDM goes wth NGK, while dodge goes with Champion. small little choice, BIG difference. its amazing how chevy & ford have the highest rates of early misfires due to their garbage coil-packs and engineering. its amazing the coil-pack design that chevy opted with (heat sink on top) and it still misfires constantly. how often has a JDM vehicle under 120,000 miles experienced debilitating misfires????AZhitman wrote:I'm gonna interject here with a quick FYI.
Until you've been to SEMA for the past 10 years and MET the representatives from the foreign companies that actually manufacture the components (bushings, water pumps, alternators, shocks, etc), don't be TOO certain they're NOT from the same manufacturer. Most actually are.
I'm not talking about supplier, or distributor. I'm talking about the actual factories that MAKE the parts. Very limited.
I don't care what "brand name" is on them, there are only a few companies supplying parts to the major auto manufacturers for each component - and they're more limited than you think. WAY more limited.
Example: Did you know that 1/3 of ALL car manufacturers use alternators AND starters from the same manufacturer? The other 2/3 of manufacturers select from another 3 companies. That's 4 manufacturers to make every OEM alternator and starter.
Fuel injectors? 4 manufacturers supplied the top 90% of all new cars produced. ALL are reputable and solid companies.
Another example: IIRC, there's only 2 or 3 companies that manufacture the wire that becomes a coil spring. By the time it's been shaped, powdercoated, stamped with a logo, and packaged, it's on the shelf as 200 different "brands".
I could tell some horror stories about some of the components in a 2009 Cube / Rogue / Versa / Sentra / Altima (I've disassembled one down to the shell and reassembled). Lots of Chinese-sourced junk, one-time-use-only parts, and things that should be metal but are plastic.
Great discussion, but let's keep it realistic (and on-topic).
The purpose of the article was to provide you with an example of a company that makes parts for multiple manufacturers since you disputed this doesn't occur. Is it that you do not believe the information in this article is correct? Or do you have a different problem? Because if you do not dispute the accuracy I fail to see what your rant on internet articles has anything to do with what I said.ImStricken wrote:i have read articles on yahoo.com regarding car maintenance and how to save fuel, etc- and let me tell you; total rubbish. typical journalists doing 15mins of research by briefly interviewing some local mechanic and then confusing his words around when writing an article. (similarly as these so called reporters are doing with guns. they are confusing and twisting so much around to their political agenda and unsuspecting people are eating it up.) so bud, forget your articles that are often written by someone who couldn't tell the difference between a ratchet and an impact wrench. forget your articles who are written by people with obvious agenda's. if they are writing articles that claim american cars have caught up with JDM vehicles - then they are either really-really stupid, or they have an agenda to try and help out the unions by pushing their cars. i speak on almost 15 years of experience- and that includes all makes/models. call your local junk yard, talk to your local mechanics and ask them which cars suffer from what problems. if you can get someone to open up, your mind will be blown. newsflash: american unions have ruined the american car. as i have stated before: the market dictates the truth. there is a reason why american garbage flopped and almost wiped itself out. over the years, people caught on and stopped buying their re-badged gimmicks. it was, is, and will be garbage that is being produced by the big 3 (ford/Chrysler/GM)
Really? Come on do you know that little about the automotive industry? I gave the example of batteries because it's a pretty cut-and-dry situation with so few manufacturers in the US.and please dont give me examples of batteries or rocker panels as proof of anything. i could careless about batteries or struts or panels or weather stripping for that matter. all of that can be replaced for pennies on the dollar, or in your case under warranty. i want to make sure the engine, transmission, and other drive-train is built properly. just because a nissan and a dodge share the same battery, both have bose audio, and both use dunlop tires, doesnt mean that their drivetrain is anything alike. that doesnt mean their piston rings are the same. there are reasons why mechanics and junk yards know which cars develop which problems at certain mileages. wanna know why? because things under the hood dont change, but rocker panels do!
Yes I have turned a wrench or two. I'm unsure where you question is going, are you about to tell me that you have formal education in the field? In my country you go to a combination of school/work experience for 4 years to become an actual mechanic. Have you undertaken similar training/education in the US to qualify your mechanical opinion as "better" than someone else?let me ask you: have you ever worked on a car? and i dont mean just changing your oil - i mean a legit job? have you ever taken a car or a streetbike and built a race-redy vehicle out of it? do you understand the technology behind how an engine works? brakes? suspension? because it seems to me that you have no clue as to what you are talking about. you simply are regurgitating so called "facts" you have read in articles.
