I disagree with JD Power reliability rankings!!
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Is this a private "discussion", or can anyone throw fuel on the fire? :poke:
BMW recalls nearly 570,000 cars to fix cables http://www.usatoday.com/story/news/nati ... s/1924627/
BMW is recalling almost 570,000 cars in the U.S. and Canada because a battery cable connector can fail and cause the engines to stall...
The cable connectors and a fuse box terminal in the cars can degrade over time, and that can break the electrical connection between the trunk-mounted battery and the fuse box at the front. If that happens, the cars could lose electrical power, causing the engines to stall unexpectedly, the U.S. National Highway Traffic Safety Administration said in documents posted on its website Saturday.
The company says in documents sent to the NHTSA that the problem stems from movement between the battery cable and the fuse box.
TrevorK
Car: 11 Rogue SV FWD
ImStricken wrote:I am not disputing that dana or texas instruments make components for many car makers. But they make those components based on the specs that car makers want. So not all the components are the same.
What are you disputing? I clearly said that "they are produced in a similar fashion". If Getrag is producing a transmission for Volvo it is produced in a similar fashion to one it makes for a Volkswagon. It utilizes similar machinery, similar manufacturing process, etc. This leads to parts having a similar quality.
So I ask again, what exactly are you disputing about what I said?
Bud you still have not answered why jdm have better resale value and last longer.
I'm more than happy to have a discussion about this however I'd like to finish our other conversation first, as quite frankly, I saw a lot of the word WRONG put into your responses from me and honestly, I have clearly demonstrated that my statements are correct and it is you who is wrong about it. I'd like to put that to rest first because I wouldn't want that to interfere with another conversation that, quite frankly, is a completely different tangent than discussing the quality of a vehicle.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
TrevorK wrote:What are you disputing? I clearly said that "they are produced in a similar fashion".
im disputing your statement: "to think that mechanically a brand is better than another where in this day and age we precisely engineer and manufacture products is absurd.". simply having parts produced by the same outsourced company doesnt mean that they are produced in a similar fashion, use the same internal components or that they are similar at all and will have the same life-span.
lets just say for example that Nissan & Dodge both order throttles pedals from "ABC Company" - that doesnt mean the two throttles are the same. Nissan's R&D and design team could have fine tuned their specifications thus reducing any issues in the future. So that makes the nissan throttle a better component than the one dodge is going to be ordering/using. There is no doubt that companies outsource to similar companies, but that doesnt mean all parts are created equal. If dodge orders parts that are poorly designed by dodges R&D team - the company making the parts(ABC Company) is not responsible, nor are they producing equally poor products for other car companies. Just because ABC Company, made throttles for Nissan and Dodge, that doesnt mean the same components were used. doesnt mean the same plastics were used(each company could pay more or less to use a certain plastic). that doesnt mean the same electrical components were used, programmed, and installed. So in the end we have two very different products, with two very different life expectancies due to the research and development and design teams from each car maker. does that make sense?
this isnt a costco where car builders walk i and point to a transmission and order 10,000. before volvo walked in and said we need 10,000 MODEL1 trannies, they tweeked certain features on that MODEL1 transmission based upon the car they want to build. if volvo wanted to cut costs, they easily could have negotiated alternative parts or slightly different design characteristics = that doesnt mean that when volkswagon walks in and also chooses MODEL1 trannies that they will get the exact same transmission that volvo got.
tweeks and design changes happen all the time, and often during 'half-year' splits. nissan could have chosen MODEL1 of something, and half way through the year called their supplier and asked to tweek the design slightly. those are called half-year-splits. does that mean that that same MODEL1 will fit in a dodge if they too ordered MODEL1? NOPE. just walk into a junk yard and when they ask you for your make/model/part - they will ask you for certain portions of your VIN number(not all cars, but many) because not every car (even if its the same make/model design) got the identical parts or programming. sometimes a certain car manufacturer will realize a small flaw or problem and make a tweek and order the same parts from the same manufacturer with a tiny tweek. that tweek could be either a better plastic or metal, or a different internal component for that MODEL1 component. that makes nissans MODEL1 component different than the one some other car maker ordered. thus making the part better or worse than other MODEL1 parts.
your idea that all cars are created/built equally just because they happen to use a similar 3rd party component maker.
TrevorK wrote:I notice you edited your post from last night, which I find interesting. The fact of the matter is clear, car manufacturers seek suppliers to build components (some extremely critical) in their vehicles and these suppliers often work with multiple manufacturers. This is the way the business is done.
i dont believe i edited my post. could have been the boss-man, as he edited the tittle as well. totally irrelevant, so ill move on. :rolleyes:
i am not disputing that car makers outsource. i got flustered when i read your post to think that mechanically a brand is better than another where in this day and age we precisely engineer and manufacture products is absurd.
TrevorK
ImStricken wrote:im disputing your statement: "to think that mechanically a brand is better than another where in this day and age we precisely engineer and manufacture products is absurd.". simply having parts produced by the same outsourced company doesnt mean that they are produced in a similar fashion, use the same internal components or that they are similar at all and will have the same life-span.
Let's look at what we have for facts, not opinion.
Fact: Parts that make up a vehicle can and are made by a third party supplier
Fact: Parts supplied by a third part supplier can make up drivetrain components
Fact: The same level of quality/workmanship/etc that goes into a product produced by a third party supplier can be duplicated for several manufacturers
Fact: When receiving a part from a third part supplier the true variable is the design elements provided by the manufacturer, meaning that it's their own internal engineering that creates the differences not the supplier
This is what we know (contrary to what you have said earlier, because that's been proven wrong). I don't think there is any disputing this.
Now where you are standing is that there are companies, in modern times (I'm not going to dispute in the past there were large disparities in quality), that have superior engineering to others and their components can have a longer usable life (note, usable life is different than total life) than a competitor across their entire lineup.
Where I am standing is that companies, in modern times, have the ability to replicate the same level of quality achieved by other manufacturers through the third part suppliers and the engineering capabilities of a single company do not outshine another.
What evidence do you have to support your theory? On my side we have JD Power, which while there may be flaws in their data (without knowing their reporting methods we can only speculate), which is an industry respected company that indicates the vehicle manufacturer are relatively close in quality. On my side we have modern engineering which allows for the manufacturing sector to easily replicate/create similar technology. On my side we have capitalist run businesses where designers/engineers are free to roam around to other employers and bring forward ideas/concepts (patents withstanding of course) that will allow the technology to be replicated. On my side we have third party suppliers making a large number of parts, such as entire transmissions, that will be able to provide the exact same level of quality that another manufacturer uses.
Again I ask, what evidence/theories do you have as to there being a significant gap in technology? We can hardly use sales of vehicles (and besides, I highly doubt the sales figures reflect the large gap) because that's not a clear indicator. We can't use the argument of "the big three were in financial problems" because it was during a global recession. So I'm curious to know what theories you have. If all it is is your opinion, that's fine, but that's hardly enough evidence to even remotely consider my theory wrong.
ImStricken06
2016 Kia Sorento
TrevorK wrote:Fact: Parts that make up a vehicle can and are made by a third party supplier
true.
true.
thats were we disagree. parts are not stamped on a cookie press and then sold to the car makers to use. because each individual car-manufacturer dictates the materials to be used by the outsourced company, each part will last longer or shorter - depending on materials used(even if the 3rd part outsourced manufacturer is the same). if nissan orders one type of plastic, versus dodge who orders a different type of plastic (from the same 3rd part maker) = the better plastic will last longer. if one car maker orders a certain LED bulb to be used for dome lights, while nissan orders a different LED light bulb to be used - the better LED will be the one that lasts longer. so no two orders are alike, even if they all order from the same company.
you seem to think that car makers pick & choose pre-made components out of a 3rd company catalog. if your theory was correct, then parts would be interchange between nissan and dodge and chevy and toyota, etc.
what makes the difference, in each specific application is the design by a car maker. if nissan sends over blueprints and schematics of a throttle to ABC CO to make and build, then their specific product will be different and possibly a better designed component than what dodge might order to be built - even if from the same company.
there are companies out there that make better quality parts over others. there are companies out there that make garbage sparkplugs(champion) and then there are companies that make 100,000mile sparkplugs(NGK and BOSCH). those are premade and easy to apply to any engine. but certain parts that are custom made by an outsourced company are specific to the car manufacturers design. (if nissan wanted to order some weird special spark plug from NGK, ngk would make it. that doesnt mean that chevy would want to use the specific deisng. heck that design could prove flawed. does that mean that everyone else is going to use the same plug? no!) if nissan chooses cheap plastic for a 3rd party company to use when making certain components = guess what.... thats not going to be the same good quality part as say if dodge spent the extra penny or two to make the same part but with better plastic.
pretend there is only one company in this world that made wheel hub bearings = do you really believe that every bearing in every car would be the same, and expected to last the same? you are forgetting that car makers spent a lot of time with the outsourced company to fine tune the product for each specific application. each car has its own specifics for the application. weight, power, reason for use. every piece of that specific product was scrutinized and specifically designed by the car maker before sending blueprints & signing contracts for the outsourced company to get busy making this specific part.
if dodge negotiates and orders rims from IMSTRICKEN LLC, and in the negotiations chose not go the extra mile on a certain metal or process - the lifespan of the rim is going to be different than say ford who ordered the same steel rim, from IMSTRICKEN LLC; but chose to take the protective paint(that dodge wanted to forgo). SAME STEAL RIM, SAME 3RD PART MANUFACTURER, DIFFERENT LIFE SPAN. GET IT?
tons of time tooling. thats my evidence. seeing certain cars coming in and having certain things go bad - even if both are made by delphi, or any other 3rd party company. some parts that dont matter much: like tires, or batteries, or light bulbs - car manufacturers really dont need to delve into. they just use what fits. thats where you mentality is correct. they literally just choose out of a catalog of pre-made parts and use them. but most of the parts are NOT chosen that way.
i never said SALES are a key element to anything. i sale REsale value is a clear indicator as to what each car is worth and why. american cars dont last long = the market which works off of resale value clearly dictates why. run the numbers yourself on any kbb, nada, galves. resale figures at the major auto auctions do dictate which cars are quality and in demand and where. drive in a toyota camry with 150,000 miles, and drive in the same condition/year/ american car thats competing with the camry = and we will see which is valued more and why. wanna know why the toyota wins in every resale value? ITS QUALITY.
actually we can. i didnt hear about honda, toyota, nissan, kia, hyundai, tata motors, needing any bail outs in order to stay alive. hell it got so bad saturn, pontiac all closed their doors. without the decades of government/municipal contracts, the big 3 would have slowly withered away. the crappy economy simply exacerbated the negative effects.
the problem with the big 3 is the sales gimmicks they ran for decades, finally caught up with them. (use your big loud car dealership commercial voice) "ITS NOT THE SAME OLD CARAVAN ANYMORE, ITS THE "GRAND" CARAVAN!!"
stickers, labels, tags, etc all caught up with them. you can only relabel the same piece of crap so many times before people catch on and stop buying the clunker. "we stopped making the cavalier" - really? opps guess you thought people were too dumb to realize the cavalier is a cobalt. the big 3 big only cared about making: bulky, beefy, cars that sounded mean and strong, and had the labels to affirm its so called toughness (hemi, trail rated, limited, daytona, powerstroke, vortex, etc) and genuinely proud americans ate up not realizing that better is out there. the big 3 prayed upon patriotic folks, and fed them garbage the whole time with their fake "american made" "build with pride" stickers and logos - when they were cutting corners and making their "american made" cars in mexico & canada. people caught on, and started to push back by going elsewhere. the market dictates who and what. the big 3 almost drowned. the big 3 struggle to hold any re-sale value at auto auctions. and the big 3 have to "donate" to magazines in order to have pro-domestic articles written. it is what it is.
trev, with all due respect; this is getting tiring. lets agree to disagree. im done on this topic, its been a pleasure sir! :cheers:
edit: check this out. will be interested to see.
http://www.kbb.com/new-cars/best-resale ... 0094158376
(the only reason the wrangler made it is the extremely large following of off-roaders & rebuilders)
TrevorK
ImStricken wrote:trev, with all due respect; this is getting tiring. lets agree to disagree. im done on this topic, its been a pleasure sir! :cheers:
For the first time in this thread I agree with you ;)
Rogue One
2022 Honda Pilot SE
Foreign brands shut out Detroit in Consumer Reports’ 2013 top car rankings
http://autos.yahoo.com/news/consumer-re ... tml?page=1
http://autos.yahoo.com/blogs/motoramic/ ... 58202.html
In a change, the magazine also broke down its scores by brand instead of manufacturer this year, charting their results based on road tests and reliability. By that measure, Lexus, Subaru and Mazda were the top three brands, followed by Toyota, Acura, Honda, Scion and Audi.
Jeep, Lincoln and Dodge ranked as the lowest brands in CR’s take, which excluded Jaguar, Land Rover, Ram, Fiat and Porsche because the magazine didn’t have enough reliability data from subscribers. As for European brands, the report was more mixed, with Audi, BMW and Mercedes on top, and Mini ranked among Detroit brands due to subpar reliability.
ImStricken06
2016 Kia Sorento
Rogue One wrote:Foreign brands shut out Detroit in Consumer Reports’ 2013 top car rankings
what happened? all i keep reading about is how SUPER the new taurus, focus, charger, and exploder are!!?? lol :lolling:
TrevorK
Wow, it amazing that the bias in the report is so great even the reporter admits it. No wonder car guys don't trust it!
ImStricken06
2016 Kia Sorento
TrevorK wrote:Wow, it amazing that the bias in the report is so great even the reporter admits it. No wonder car guys don't trust it!
hence why i previously stated:
"i have read articles on yahoo.com regarding car maintenance and how to save fuel, etc- and let me tell you; total rubbish. typical journalists doing 15mins of research by briefly interviewing some local mechanic and then confusing his words around when writing an article. (similarly as these so called reporters are doing with guns.)"
"so bud, forget your articles that are often written by someone who couldn't tell the difference between a ratchet and an impact wrench. forget your articles who are written by people with obvious agenda's."
if CR gets a "donation" from ford, in next months issue, magically, there will be some great review of Ford cars. its all games & crap. media of all shapes & sizes are starving for attention and donations and will do ANYTHING to garner any form of income. hence why i dont take anything seriously that i read in any of these rags. most of the so-called "journalists" (aka bloggers without a clue) couldnt tell the difference between a piston and a universal joint. they write well, they review well, but when it comes to real life tool-time = zilch. hence why i keep reading articles where these so called journalists rant & rave about self-destructive behavior: "dont pollute, so dont warm your car up. plus with todays engines its not necessary to warm them up.". YA F-THAT! if you wanna blow your engine apart; do it. but dont you dare write about it, like you know what your talking about. :end rant:
jcircus
Car: 2012 Nissan Rogue SL AWD
wow interesting read here. I have to say, I actually think your both right (to a point). This is just my opinion, with no facts but years of experience to base this on. I worked for Lincoln Mercury / Ford from 1983 to 1995 as a Journeyman mechanic, trained at Ford factory centers, and my 2 years of college provided through the Ford "Asset" program.
That was 20 years ago, but one thing i learned was that manufactures actually use lots of the same parts, platforms and manufacturing plants.
For example, I at one time owned a "Ford Probe".. which is actually built on the Mazda 626 platform.
The Probe was fully based on the Mazda G-platform using unique sheet metal and interior.
http://en.wikipedia.org/wiki/Ford_Probe
The "Mercury Villager", was in fact a Nissan Quest under the hood.
The Mercury Villager was a minivan, marketed by Ford from model years 1993–2002. A rebadged variant of the Nissan Quest, the Villager was a product of a joint venture between Ford Motor Company and Nissan and was built at Ford's Ohio Assembly plant in Avon Lake, Ohio.
http://en.wikipedia.org/wiki/Mercury_Villager
Now, does this make them the same in quality? absolutely not!
This is just a single opinion, from an old mechanic.. but Japanese branded / manufactured vehicles (as a whole) have always had much higher quality and lasted longer. Why? not entirely sure myself, but possibly just because they had higher standards during manufacturing? I can't really point to any facts, but to this day I own 2 toyotas and 1 Nissan. my last domestic vehicle was a loooong time ago, and i will never go back. This is based on years of working on thousand of them (all brands) and coming to my own conclusion about thier quality.
I agree, the JD power rankings is BS.
ImStricken06
2016 Kia Sorento
jcircus wrote: For example, I at one time owned a "Ford Probe".. which is actually built on the Mazda 626 platform.
This is just a single opinion, from an old mechanic.. but Japanese branded / manufactured vehicles (as a whole) have always had much higher quality and lasted longer. Why? not entirely sure myself, but possibly just because they had higher standards during manufacturing? I can't really point to any facts, but to this day I own 2 toyotas and 1 Nissan. my last domestic vehicle was a loooong time ago, and i will never go back. This is based on years of working on thousand of them (all brands) and coming to my own conclusion about their quality.
dodge caravan had Mitsubishi engines.
dodge stealth and Mitsubishi 3000gt?
how about eagle talon & mitsu eclipse? plymouth laser's lol <---memories! lol
Rogue One
2022 Honda Pilot SE
ImStricken wrote:...if CR gets a "donation" from ford, in next months issue, magically, there will be some great review of Ford cars. its all games & crap...
I used to speculate if Motor Trend's Car of the Year went to the highest bidder. :gotme
CR is, and always was been, next to useless for 90% of the stuff they review. Primary problem is that by the time the printed issue hit the newsstands, the stuff was dated, and some items discontinued.
JD Power's surveys aren't that reliable, as they will omit anyone that consistently returns negative surveys.
Return to “Rogue Forum”
