boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Fri Jan 23, 2004 9:03 pm
The only problem with doing the mains is if you go that far, change the oil pump as well. But then again, if you're going to be taking out the engine and taking off the head, go for it all to include rod and main bearings, oil pum, fresh set of gaskets and seals, timing belt, water pump, and new rod bolts to boot. You're looking at less than $500 for all those goodies which will ultimately guarantee you a very fresh start. Is it worth it Tim, yes! If you have another car to get you around whiles yours is under repairs, I would definitely suggest sourcing all the parts 1st and going for a complete clean-up. You won't regret it and you'll know what's in there and besides that, it's really not that hard to do except for the crankshaft timing belt sprocket.
Dee
