ok, wish me luck guys
boost_boy
Do you know of anyone who uses the emanage on the CA18DET. If you know someone who does it on a n SR, you cannot and should not duplicate their settings. SR's need more timing than the CA18 and if you try and run anything than what's need, pop goes the weasel. The CA18 does not like a gang of timing like the SR.
nab911
Car: 93 Nissan 240SX SE
I heard of people one these boards but im going to take it to Balanced performance up here because they have a REALLY good rep and have them tune it. Because i just broke the inground dyno in my basement and my wideband o2 sensor is lost :)
boost_boy
Quote »Because i just broke the inground dyno in my basement and my wideband o2 sensor is lost [/quote] Wake up Cinderella:icesangel
nab911
But seriously, if you think everything is alright, after fuel management and tuning... what exactly will 17 lbs do to my motor :)
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
well, if youve got all the necessary items to do such tuning, fuel, fmic, turbo, etc. it should just give you a good raping of the bum when it slams you back into your seat. thats about it.
and thanks for all the help! my dad and have decided to change the rod bearings and the head gasket for now, but depending on how other things look we might go for mains and oil pump and such. currently im looking at a metal head gasket, rod bearings and arp head and rod(?) bolts.
- tim
r34 gtr
schwing! theyre not that expensive!! i can actually afford to get them! do i want the ca18de or ca18et bearings? im guessing the de. and hwere do i go find arp bolts? anyone have the part numbers of the bolts i need?
- tim
nab911
whoa paco, calm down... almost all the de parts fit for det, check the crossover parts sticky and dee knows where to get arp bolts
boost_boy
Quote »But seriously, if you think everything is alright, after fuel management and tuning... what exactly will 17 lbs do to my motor [/quote] Wake it up! Tim, part #s are on here as we've just discussed this in the last week. You will be using all parts off the 1988 nissan pulsar with 1.8 litre motor.
nab911
is it the Nissan Pulsar NX SE? Or the XE? I think its the se but im not sure...
boost_boy
SE!
