quote="BigTDogg (MA)"]
NolimitZ32 wrote:For which setup? the 700s I would go with 850cc modded and flowed injectors just because I like the peace of mind of having some safety margin, some don't trust modded injectors so they go with custom setups with top feeds and BDE or Win Factory Rails. Specify what setup you are talking about and I can try to give you more info.
I'll be that guy; I would not use flow "modified" injectors. The link on the first page explains why.
For the GT28RS, either the Z1 kit or JWT kit, I'd consider either the Nismo 740s or the Injector Dynamics 1000cc/min injectors with the BDE top feed rail. Do not get the Lose Factory rails, there have been too many issues with their install from everyone who's bought them. 740's would be fine with meth injection and pump fuel or race fuel, but if you're running just pump fuel, you may have headroom problems. At that level though, you may need to consider an inline Bosch pump to boost your fuel pressure. You can email Greg at Specialty Z for more info on that.[/quote]
again, second to everything this guy says ---- what some people also do op, is run dual-oem fuel pumps, they're very high-quality (superior to walbro fuel pumps).
the hks front mounts aren't the best, i'd go with aspec massives smic's or the tdm fmic.[/quote]
_______________________________________________________________
Ill look into the options vulcanrush... what are you running??
