It sure does, but he said he's gone over them and found nothing, maybe he just need to look harder *shrug*paemt6220 wrote:I'm not the most experiened person here, but that sounds like a vacuum problem to me! Check all the vacuum lines.
Chad
thank you I was thinking about the waste gate as well - but the other stuff didn't come to mind. I'll write them down and let him know.S14tat wrote:i would check to see if the wastegate is stuck open. also i would the air flow meter, not to mention the blades on the compressor wheel. i bent mine and it wouldn't make any boost. and it sounded weird as hell when its close to boosting. not to mention check to see if the blow of valve is leaking or stuck open.
Again - I'll write this down and let him know.fiznat wrote:I'm thinking it is most likely a mistake on your mechanic's part. Issues with no boost are usually a boost leak before or in the intake manifold, or an exhaust leak before the turbo. Based on the things your mechanic pulled apart and replaced, the potential is there for all different kinds of leaks.
I've said it once and I've said it again... why oh why do you keep going back to this damn mechanic??
I will tell him to do so - thank you98s14inaz wrote:Start checking everything with soapy water in a spray bottle. Greg and I found a **** ton of leaks on his KA-t vert when we did that. One particular one was that little selenoid/valve under the intake mani in the middle. It has this little nut in the back that was leaking air. We took off the nut, put some rtv on it and the threads, put in on, let it set up, no leaks. Car builds boost just fine now.
Recheck the mechanics work. He missed something.
Will add that to the list. As far as the soapy water - it'd just be in a little spray can, not like we are dumping a bucket on it - but I understand what you mean..I'll have check all the stuff mentioned in this thread, and if it comes down to it - he'll have to bust out the spray if that's what it takes to find what leak is coming from where.C-Kwik wrote:Since it's idling terribly, I'd have him check all the intake plumbing. It possible he forgot to tighten a clamp or something when re-installing the turbo. This could both cause a lack of boost and poor idle.
I'd refrain from using soap and water to tryand locate this leak. Since you are probably not going to be able to check it effectively under boost, the system will likely be in vacuum. This means the sopay water would only get sucked in if anything. #1, it won't do much to help you find a vacuum leak. #2, do you really want to be sucking in soapy water?
Probably not an exhaust leak as idle wouldn;t be affected and you would likely hear it. An open wastegate would also not affect the idle.
Will have him double check itlrb_2000 wrote:plug your MAFS back in. haha, jk, but seriously, it happend to me.
That is why you rig a pressure cap and pressurize the system. Greg came up with quite an ingenious set up using nothing but a tire nipple and some stuff from hd. We located all of his leaks with soapy water and the system holds pressure now. I should have mentioned that in my previous post. Ask Greg about it.C-Kwik wrote:I'd refrain from using soap and water to tryand locate this leak. Since you are probably not going to be able to check it effectively under boost, the system will likely be in vacuum. This means the sopay water would only get sucked in if anything. #1, it won't do much to help you find a vacuum leak. #2, do you really want to be sucking in soapy water?
When are you & Greg gonna do a write up w/ the soapy water and teh rigged pressure tester? Sounds like a realllly useful tool for everyone. May seem easy to you guys since you know what you're doing, but I can only guess how to go about it, haha.98s14inaz wrote:That is why you rig a pressure cap and pressurize the system. Greg came up with quite an ingenious set up using nothing but a tire nipple and some stuff from hd. We located all of his leaks with soapy water and the system holds pressure now. I should have mentioned that in my previous post. Ask Greg about it.
Ah. That makes more sense. Though, that's a lot of trouble to go through IMO. It would probably be reserved as a last resort thing for me.98s14inaz wrote:
From what I gather it isn't boosting AT ALL. I will have him check that. thanks.paemt6220 wrote:Is it boosting at all? If it is, but its low boost, check wastegate LINE. That would cause a bad idle and only let you boost to the wastegate spring psi.
Chad
He can drive it, he just says it runs like **** and doesn't boost - so, yes, it is revving.Craving4Boost wrote:is the car revving though?? if the car isnt even revving..than something is probably clogging the turbo..your mechanic may have put to much oil clogging it
If that was the case, wouldn't it cause the wastegate to remain shut, and continue building boost?paemt6220 wrote:Is it boosting at all? If it is, but its low boost, check wastegate LINE. That would cause a bad idle and only let you boost to the wastegate spring psi.
Chad
I can't take any credit for the apparatus Greg rigged but I did start using the soap and water when we couldn't find the last stubborn leak on his set up. He just got back from atlanta and I am sure he has stuff to do, i'll ask him about it next time I see him.brokeAs240sx wrote:When are you & Greg gonna do a write up w/ the soapy water and teh rigged pressure tester? Sounds like a realllly useful tool for everyone. May seem easy to you guys since you know what you're doing, but I can only guess how to go about it, haha.
Yes, UNTIL the boost reached the wastegate spring's pressure, then it would open! If the wastegate spring is only like 5 or 7psi(which is common on most turbo kits), that would mean you would boost to there, but no higher.SloMoe wrote:If that was the case, wouldn't it cause the wastegate to remain shut, and continue building boost?
So you're still going to the same mechanic?Mustangs_Suck wrote:Ok..he said he found the problem..
He said the ignition coil is giving out .7ohms instead of 1ohm, and it is fouling up my plugs in a matter of minutes. He said it's all messed up electrically wise as well - so he found another ignition coil, and will be buying brand new NGK plugs and gapping them to .30 and hoping it will solve all my problems.
Lol, it's been sitting at his shop for literally over a month.brokeAs240sx wrote:So you're still going to the same mechanic?
Hope you get to drive your baby soon.
