enthalpy. then tweak with safc2 if needed.FSUDrifter wrote:yeah so greddy intake instead of cams...
next question: Enthalpy tune or Power FC?
I'm not really planning on modifying the car much after this. I just want it to be reliable as possible.
Camshafts will make much more of a difference than intake manifold, especially with a T2 based exhaust housing. In your situation, I'd go:FSUDrifter wrote:yeah so greddy intake instead of cams...
Such mild cams such as the 256 won't affect your low end as much as you think.FSUDrifter wrote:well i was thinkin that cams would hurt my low end and this car is gonna be driven in a lot of stop and go traffic so i need low end.
- is power fc really worth it if i'm not really planning on changing my setup?
- is 8k miles too much for a used turbo?
highmilehatch - I live in florida so unless you know of an authorized tuner in florida i was thinkin the place in kennesaw if i go that route.
Check the advertiser specials. They're having a good deal on NGK widebands, or check out Innovate or Zeitronix.FSUDrifter wrote:So is there a certain wideband that you all would recommend?Modified by FSUDrifter at 8:22 AM 8/5/2006
http://apexi-usa.com/dealers_powerexcel.asp Here ya go, hope this helps you in your endeavors!FSUDrifter wrote:does anyone know if there is anyone in the florida/alabama/georgia area that can tune a power fc? i saw one place in kennesaw, ga but that's like 5 hours away.
