oil type synthetic really worth it?
Turb0wned
i been running regular castro high milage 10m-40 oil in my sr snice ive had it and have had no problems ive prob put about 15k on my sr by now i dont see how synthetic is acually worth the money... or even worth putting in, im not trying to argue with anyones opionions matter of fact i would like to hear what ur thoughts on this topic are, im going to be changing my oil again within the next few days and maybe ill switch to synthetic...
Nismo_Freak
Car: 89 Nissan 240SX
It is, but many people don't quantify the cost difference with the frequent oil changes.
Then again your strongest dyno oil can be better than your worse synthetic. However if you buy a quality syn. you can't beat the package.
Hijacker
Car: '92 240sx Convertible
'94 F-150
the thing with going synthetic is the heat resistance. You're not going to see how much coking of the oil that will come from running dyno oil for a while, but I can guarantee that there is probably some buildup in the turbo.
PalmerWMD
Car: 2004 350Z
For a turbo application its pretty hard to beat a syn..Summer or Winter..
Fred..
Turb0wned
so go synthetic?
kuramaya
Car: 1995 RPS13 180SX
Any Car - Yes Synthetic
Turbo Car - Synthetic 15W 50
If you can afford it - HKS Super Turbo Racing Oil 15W-50. If not Mobil 1 is fine.lateDaryl
Turb0wned
15w-50 really... isnt take a little thick
kuramaya
Actually no unless its winter, freezing where you are, and you never run you car hot...actually it is the only weight the HKS oil for Turbo APS is sold over here....additionally, its the only weight of mobil 1 that is sold on or off base. Everyone I know which includes every SR powered car, and RB Powered Cars all run 15w-50. I have been running it as long as I have had the car..lateDaryl
SpeedRacer1
Car: 1990 240SX, G35
I run 10W30 in winter, 15W50 in summer.
Turb0wned
what do u think about redline 15w-50?
kuramaya
Redline is great stuff!
s13sr20chris
i prefer redline. if you cant afford a synthetic you may consider a motorcycle oil as they all have zddp afaik.
Turb0wned
yea im thinking about goin with redline from now on
Hijacker
'94 F-150
SpeedRacer1 wrote:I run 10W30 in winter, 15W50 in summer.
ditto
TogueDrifter
Car: 91 B13 SER
I just put in 10w40 castrol syn. I'm happy
deCksy
TogueDrifter wrote:I just put in 10w40 castrol syn. I'm happy
lol... kinda old post to revive... but NEO is the **** 15 50 here NEO STYLE!
DRIFTINIZ
anything bad w/ 5W-30 Mobil 1 Super Syn......i haven't driven the car w/it for more than 100 miles.......?
UK-SRi
Car: Nissan Cima 2007/2008
Look on Se-r.net some ofg the guys there have done 100K+ and track racing too with 5W30 and still found honing marks when stripping down.
Mike
TogueDrifter
Car: 91 B13 SER
Oh, Sorry.... I miss understood, too tired last night
DRIFTINIZ
UK-SRi wrote:Look on Se-r.net some ofg the guys there have done 100K+ and track racing too with 5W30 and still found honing marks when stripping down.
Mike
honing marks......please explain.....still learning stuff here LOL
Nowhere
Car: Suzuki x-90, samurai
Hone marks are on the piston bores, they are the criss-cross pattern grooves that hold an oil film (ultra thin..) to keep the friction down on the up/down stuffs (pistons, rings).
That means the engines are experencing little internal cylinder wear (high friction will remove metal from the walls, scraping off the hone marks) with the 5w 30 oil.
some VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY VERY good reading on oil:
http://63.240.161.99/motoroil/index.html
It's looong but goooooood.
READ IT!
srdrps13
Car: s13
ive been using mobil 1 synthetic 10w30... is this alright?
DRIFTINIZ
Nowhere wrote:Hone marks are on the piston bores, they are the criss-cross pattern grooves that hold an oil film (ultra thin..) to keep the friction down on the up/down stuffs (pistons, rings).
READ IT!
so with the 5W i should be good??
hazw8st
Yes it is worth it....
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
I run Mobil 1 10w30 in all my engines.
shadowracing
Car: 1990 nissan 240sx
since i got my sr i've doon 2 oil changes the first with royal purple 10w-30 and felt improvement, so yeah you get what you pay for. also how often does everyone change their oil?
FattyMcBaggins
Car: 1990 Nissan 240SX
I cannot stress enough how important using a synthetic oil is. Synthetic's virtually eliminate the threat of coked turbo bearings because the elements that cause coking are barely present in synthetics. Also, I'd stay away from Castrol products. I worked as an intern with Shell Corporation, and did a bunch of studies and such on other oil companies business practices. castrol has a bad reputation for being a CHEAP manufacturer. They don't pump their own dino oil, they buy their oil from whoever is selling it the cheapest. This makes it hard for them to really maintain a quality product. They also buy the ingredients for their synthetics in the same manner. Mobil on the other hand pumps their own oil, refines their own oil, and then sells it, so they actually control the entire process involved with their product. I would recommend using Mobil 1 synthetics without any second thought. I personally shy away from "Racing Oils" because they're meant for...well...racing. They may be able to tolerate higher heat levels, but they also aren't meant for putting around town and such. I remember reading an article about Racing Oils tending to be very ineffective for regular street driving. use Mobil 1 most of the time, and toss in the racing oils whenever you have a track day. That's what I would do
hazw8st
Turb0wned wrote:i been running regular castro high milage 10m-40 oil in my sr snice ive had it and have had no problems ive prob put about 15k on my sr by now i dont see how synthetic is acually worth the money... or even worth putting in, im not trying to argue with anyones opionions matter of fact i would like to hear what ur thoughts on this topic are, im going to be changing my oil again within the next few days and maybe ill switch to synthetic...
Synthetic is the only way to go....
Neil
Car: shooting laser guns
I finally put 10w30 mobil 1 in my SR this evening after running a couple short "flushout" dyno oil changes after my swap.
I noticed the motor had a new high pitched metallic sound to it. Drove into town and it went away ::shrug::
p.s. K&N filters on a filter relocate kit are the PWNZ!. since they have an anti-drainback valve the filter stays filled with oil instead of draining back down to the pan, this means oil pressure builds instantly like it should instead of having the valvetrane run dry for a second.
DRIFTINIZ
p.s. K&N filters on a filter relocate kit are the PWNZ!. since they have an anti-drainback valve the filter stays filled with oil instead of draining back down to the pan, this means oil pressure builds instantly like it should instead of having the valvetrane run dry for a second.[/QUOTE]
do fram filters have the same anti-drainback?? just curious.....
