Oil Temperature
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
what oil temps do you guys reach on the highway? cruising around city and on the small highway here at 55mph or so i hit like 230*F max..im supposed to go about 1.5hr away so i wanna be sure. Thanks guys.
Bumnah
Car: 1992 240SX, black. Bone stock.
185-195 on the street
221 on the track.
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
sjbsuperman1425
CA18DET
how did you guys mount the temp sensor, just an oil filter adapter?
DrJuice164
Car: 04 G35 Coupe
Mine is jbwelded in the oil pan. Going to relocate it to my oil block whenever I get remote oil filter/cooler.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
It should be about 10-15 above coolant temp.
I read mine at the oil pan, welded fitting.
Oil coolers are good, but they should be thermostat controlled. You want your oil and coolant temp to be in proportion.
sjbsuperman1425
CA18DET
is it possible im not getting a good reading from the oil filter adapter im using? i dont have an aftermarket water temp gauge so idk what that is, i just have my fan switch set to go on a when the needle goes halfway on the stock temp gauge..
i'll probably look into an oil cooler over the winter (funds short now)
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You could, those sandwich blocks are usually a good spot for connecting a pressure gauge, but you could use that fitting for temp. Your better off using that fitting for pressure, getting a real water temp gauge, and putting the oil temp gauge in the oil pan. Just gotta drill a hold and weld a fitting on.
sjbsuperman1425
CA18DET
alright. because right now i have my temp and pressure senders in the filter adapter. usually around city though it never shoots past 200*F though, but i'll check it the next few days to be sure.
sjbsuperman1425
CA18DET
yea city driving never went over 210*F. i mean is there any significant damange if my oil temp gets over 250*F? I just recently found out that im going to have to do alot of highway driving.
sjbsuperman1425
CA18DET
heres a couple pics. one of just the temp and one of temp/press.
the temp was at that after about 20 to 30 minutes of back road driving at 50mph. i read somewhere that the oil temp should be 30-40*F higher than the coolant temp? Anyone think i should be overly concerned about a highway drive with temps like this?
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
If you're taking your reading from a pressurized spot, it probably won't be accurate. Try running your oil temp sensor into the bottom of your oil pan. It will be at peak temp there, too.
210 is too high for normal driving. You should be down in the 190 area.
karmakaze
Car: 98 240sx SE
i have hit 185 when driving my car hard in the heat. my temp sensor is on my oil filter adapter although i don't know what it would be at the track yet.
normally its around 170
but i have an oil cooler from an rx7, which in combination with my oil pan means my car takes 6 quarts of oil. the rx7 oil cooler looks like a small intercooler and has an internal thermostat (set to 170).
pimp s*** it is.
mattblancarte
Oil cooler ftw
Bumnah
I take my temp from the oil pan as well.
sjbsuperman1425
CA18DET
alright, sounds like this winter im getting an oil cooler and having my oil pan fitted with a fitting for the temp sensor. Thanks guys. I'll just drive it like it is and not worry about it then. as long as i have pressure i should be ok.
For the oil cooler, imma just wrap up the Isis SR20 kit off Enjuku and get a Greddy thermostat adapter.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You and me both lol.
You need to run an oil thermostat, you can build your own kit.
Just get a nice cooler, AN fittings, a thermostat, and some heat wrap.
My LS6 runs warm.. Coolant is running up to 225 after running a while, and my oil creeps up to match of coarse. So I just spend a ton on better fans, cooling panel, and I will be adding an oil cooler. Cooler oil will also cool the motor overall, you should see a coolant drop as well.
Check this out.http://www.racerpartswholesale...ostat
From supramania.http://www.supramania.com/foru...62838
sjbsuperman1425
CA18DET
i thought about building my own, but the cost would almost be the same as just buying parts that are ready to be installed. plus i've never made SS lines with fittings before so i feel safer spending the $$ on the Isis Oil Cooler and buying a Greddy Oil sandwich w/ thermostat. i think it'll be like $350 tops all together so its not that bad. Thanks again guys.
mattblancarte
OutToWinPAHC wrote:So I just spend a ton on better fans, cooling panel, and I will be adding an oil cooler.
Ugh... I spent so much dough on keeping my 26 cool.
sjbsuperman1425
CA18DET
its kind of funny..since i removed the heat sheild under the hood, everytime it rains, i can watch the water evaporate xD
maryjane
mine stay between 160-175 on street 190 on track days
dc1984
wow, 100+ bucks for an oil thermostat. i live in southern california and dont realy feel that it i needed one when doing my oil cooler as im usualy wearing shorts and sunglasses for x-mas. ive heard some good things about that new ISIS product at enjuku. they say that their intake manifold is supposed to be a pretty good alternative to the 400 dollar more greddy manny.
DrJuice164
Car: 04 G35 Coupe
240sxmotoring has something like that but it is built into the filter housing. They come in either just for an oil cooler setup (sandwitch style) or cooler and remote filter setup (need an oil block).
http://www.240sxmotoring.com/groilcoadw.html
http://www.240sxmotoring.com/gr12reoilcof.html
So your looking at around 700 bones for a full filter relocate and cooler setup. Which is still cheaper than the Greedy kit and your not limited to the lenghts supplied in the kit so you can mount it anywhere and just have custom size lines made.
sjbsuperman1425
CA18DET
yea im not really looking into a filter relocation, i dont really see the need, as this is mainly a street driven car, and having fun on the side. Thanks for the research though!
DrJuice164
Car: 04 G35 Coupe
Then you can just get the sandwich adapter and run an oil cooler off that, done.
But as said above, if your oil temp sensor is in a pressurized spot aka anywhere but the oil pan basically, it might read improperly.
mattblancarte
Yep, a sandwich plate is the easiest way to do it.
Make sure you're running nice AN-10 or AN-12 fittings from the sandwich plate to the cooler. You don't want to create any more resistance for the oil pump to deal with.
Here's what my system looks like:
sjbsuperman1425
CA18DET
yup, took my car for a drive on the highway for probably 20 minutes and buried the oil temp gauge so im thinking its not accurate lol. the water temp stayed perfect.
dc1984
sjbsuperman1425 wrote:yea im not really looking into a filter relocation, i dont really see the need, as this is mainly a street driven car, and having fun on the side. Thanks for the research though!
the oil flter relocation is convenient on an sr, the filter is burrid under the intake mani. now its right out in the open, i appreciate it every time im doing my oil change.but if u do end up doing an oil cooler/relocation kit, id recomend doing it custom so u wont be restricted with the location of the cooler or filter reloaction. u can just cut the hose lengths as long as u need them based on where u want to mount the cooler and whatot.ve never realy heard anything about taking temp degrees from a pressurizd spot. i have mine coming from the oil filter relocation plate. maybe i should look into that one
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
How large of an oil cooler are you going with?
maryjane
im using a greddy relocator to a mr gasket truck oil filter housing, then into a 12x14 bnm oil cooler then back into the motor
