mikesloud »
https://forums.nicoclub.com/mikesloud-u11926.html
Tue Jun 14, 2005 10:54 am
Yes, that could be true but if you rate of oil coming in and oil going out is relative same and the fact the oil pump is always sucking and keeping the oil levels lower you should not have a problem, many,many KA-T people have put the right size restrictors and not had any issues with seals blowing ,except when too much oil was being pulled in ( not small enough restrictor from hi pressure outlet)It is not worth all the trouble , just put bung as high a possible and get the right size inlet restrictor.
