did you locktite the oil pump screws? they are notorious for backing out on pumps.......and yah that crank bit is exactly what i was talking about, the crank drive is too short on some cranks and the oil pump starts to freewheel.jmdser wrote:Its the original pump. I did take it apart and check the clearances before I put the motor in and it looked in good shape then. I guess its time to pull it apart. That sucks, I really wanted a new turbo.
Modified by jmdser at 2:37 AM 11/10/2005
Nice Is your car running with the new external oil pump set up ?I am intrested in following in your footsteps !RBTALLY wrote:yes the rb25's the same problem in some years.. I michened a collar for my crank and had it pressed on and pined also . It did work but I was still worried about it so I have now switched to a external oil pump
Stock redline is around 7100 rpm (gauge reads 6800), so you should be okKansei240sx wrote:So if i only max out at say 6900-7000 is that pushing it?
I still would like to know how to hook up and external oil pump and or where i can get one.
That crank has the short drive on it. Look at the area that engages the oil pump drive, its very narrow, and from looking at the discoloration on it, it is only engaging halfway onto the oil pump drive gear.Kansei240sx wrote:OK, last night i took off my dented oil pan, ( now undented ) and got down to my oil pump and looked at the crank collar.
The engine is out of a 1996 R33 and its a series two. Now, from what i've read the only engines that have the crank collar problem badly ( coming from skylinesdownunder and skylinesaustralia, say that its the R32's with the 26 and 20, and that they havent heard much of a problem coming from the RB25DET unless you have 500+ hp.
Now my question is, from you guy's perspective, does my crank collar look damaged much? i mean, the motor has around 40km on it and everything i've torn down on the motor so far has been in excellent shape, The bottom end is also rock solid.
If i am only really working for about 350-400 rwhp as my goal way later on down the road, should i be fine with the current oil pump and collar? and if not, WHO and how can i set up an external oil pump.
My mods list will be for the beggining, 3 inch exhuast from turbo back, Megan large fmic, MBC on 12 pounds, greddy intake manifold, adj fpr, intake bov and a few small other misc things.
That guy seriously needs a good . I would not take anymore advise from him.Kansei240sx wrote:I was talking to a guy i know thats done this to similar cars that have a crank driven pump and he just put a not super thin layer, but moderate layer of JB weld on the inside of the oil pump where the collar meets it and it kept it snug and didnt ever want to freewheel.
I don't like the idea of welding the snout on the crankshaft. To weld to a piece of forged steel like that with any success you will need ALOT of heat. Heat distorts metal. I am not cool with the idea of possibly warping the snout and rendering my crank useless & unbalanceable. JUN's collar is around $150 and isnt terribly hard to install. To em welding extra material onto the snout is akin to the JB Weld route.Phat_Optimo wrote:The best way to deal with the crank with out going to an external pump is to have the flats extended. you can either buy the collar or have it welded and machined. I like the latter of the two but definately no jb weld.
