it depends if you like to follow torque specs and do the pan bolts correctly or just do it however you can. No the crossmember or motor doesn't need pulled but it is a lot easier to pull the motor since the ka is a breeze to pull in and out. I can say even my little inch pound torque wrench is impossible to get to a few of the pan bolts. Btw get a op gasket when you do it, much more reliable seal imo than just rtv victor pn os32110.tramp_drift240 wrote:LOL, shut up.
you dont have to remove the cross member OR pull the motor out to get the oil pan off. you just need to disconnect the engine mounts so you can jack the motor up enough to clear the crossmember.
though believe it or not, it might be easier to just pull it out and fix it. instead of working between the radiator support and the motor, the hassle of getting the oil pan out, etc.
Thats all your supposed to usetramp_drift240 wrote:do people actually seal their oil pans with ONLY rtv sealant?.
No it's not, it's bad to use. Always go with a gasket, don't go cheap. I have seen too many engines where they tried to use rtv and they either smeared it while putting it up there causing a leak, putting it on too thin or they tighten too much pushing it all out. Go with a gasket.n240sxfnatic wrote: Thats all your supposed to use
LOL, why do they make a gasket for it?n240sxfnatic wrote: Thats all your supposed to use
Oh man im sry my bad... O wait your retarded. Liquid gasket is just that A GASKET, and tightening it down till it oozes out is fine. Think about it; The extra oozes out because it is so compressed and SEALED that all it can do is go out.ilovesideways wrote:
Yes i use rtv on the parts of the cover that require it per FSM.tramp_drift240 wrote:
do you use RTV for your valve cover as well?
get over yourselfslyedog240sx wrote: As far as anyone who won't torque any tin or other covers that mates a gasket, you are inexperienced and need to stfu cause you aren't professional and are plain ignorant.
Did you also notice that the fsm I posted was from a ka24de?ilovesideways wrote:I just noticed you own an SR, no wonder...
Yes I did...and I also noticed you own an SRn240sxfnatic wrote:Did you also notice that the fsm I posted was from a ka24de?
sure thing buddy.You would do it if you knew what you were doing. get some years of experience under your belt, or you will learn the hard way installing helicoils all the time.Nuff said.tramp_drift240 wrote:
get over yourself
i know what im doin, so you just do your extra work for no reason when i can do the same job in less time and still, no worries.
Helicoils are only necessary when bolts are tightened too much.slyedog240sx wrote:
Yeah it is...it just proves to me that Retard and owning an SR go hand in Hand. SR=Stupid & Retarded Motor.n240sxfnatic wrote:so so owning an sr is hilarious?
n240sxfnatic wrote:Haha, you seriously have to be the dumbest person on this forum bar none.
No that title belogs to NALA. The SR is inferior to the KADE in many ways and is inferior to loads of other motors as well. Why anyone would spend $2500.00 to swap and SR is beyond me. People who own SR's remind me of Honda guys...they are all about hey look at me! Look how high I can rev my motor! Even though I have no torque and a ****ty block.n240sxfnatic wrote:Haha, you seriously have to be the dumbest person on this forum bar none.
No...I didn't say my motor was better I just said SR's are ****. Personally I would take a KA24DET over an SR20 anyday....I'd take a KA24ET over one. Either one could have more horsepower and a buttload more torque for half the price of an SRtramp_drift240 wrote:
ilovesideways, are you jealous of your stock motor or something?
Hahaha...I can't afford to do things to my car because I don't own an SR? I can think of ten different motors right off that I would rather do than an SR (and be able to afford them) Ka's are superior to SR's when built. Why don't you stop being so opinionated and **** off? I think you just earned the title of forums biggest retard...You want a dunst cap to go with that tramp?tramp_drift240 wrote:
youre talking out of your a**, and trying to start another lame sr vs ka thread.
a bare stock sr will kill your 240, im sure.
hell, an sr20de NO TURBO will probably stomp your car.
stop being so opinionated just because you cant afford to do things to your car.
if i were a mod, id lock it up.
Ok, this is a thread about an oil pump not arguing motors. I have a Sr, so what? I had a ka.. who cares. You cant even compare a built ka to a stock sr BUT you can compare a built ka to a built sr. Power is based on how much you have to spend. Oh and the sr= stupid retarded thing just shows you are a child looking for anything to try and not look stupid, by having people think that is funny; It wasnt. You dont know what ur talking about so please stop talking, your just looking dumb. The op has his answer and a mod should lock this up tight.ilovesideways wrote:
Hahaha...I can't afford to do things to my car because I don't own an SR? I can think of ten different motors right off that I would rather do than an SR. Ka's are superior to SR's when built. Why don't you stop being so opinionated and **** off? I think you just earned the title of forums biggest retard...You want a dunst cap to go with that tramp?
BTW I already have a motor swap for my car.
