cartoonlips7 wrote:the gauge was free. its in bar tho. one to seven bar.. electric. myn goes to seven stays there til motor warms then down to one bar.. does anyones pressure go up with rpm? sometimes pressure drops off and fluctuates...>?
I don't understand your post in relation to the OP, but do you guys realize that this thread is 2 years old? LOL
EDIT: While the FSM (S14 SR20) has no cold PSI rating, it does state with the engine at normal operating temp, under no load, it should run more than 11 PSI at idle and b/t 46-57 PSI at 3,200 RPM.
Modified by homeslicej2 at 8:20 PM 1/2/2010
