Good point, I didnt even think about that.boro drift wrote:Also check the oil pan. Make sure its not bashed in.
Mine was, I hadn't even though of that, its been too long.boro drift wrote:Yeah, alot of oil pans get bashed on the boat ride over.
It can, if it is clogged, you most likely have bigger problems, as the only things that can clog it are metal (BAD), or cooked oil, also bad, but not as end of the world. Either way it can be cleaned out, but there are often bigger problems.boro drift wrote:I've also heard that the pick-up screen can get clogged, is that true?
Thats funny because Ive been around quite a few 22R/22REs, and Ive never actually torn one down. This probably has something to do with the fact that they never die.boro drift wrote:I read about that somewhere I can't remember. But every 22R I've been into has had timing chain guide chunks stuck to the screen and in the pan.
