Morph »
https://forums.nicoclub.com/morph-u11938.html
Thu Nov 10, 2011 11:38 am
Hey guys, in need of some info I cant seem to find. I took off my Oil Pressure switch before swapping the motor back in (not sure exactly why I did this) and I can’t find what to torque it down to. I remember when I took it off the damn thing was snug has hell. I’ve already rethreaded it and tightened it down but I just want to make sure I didn’t put too much pressure on it or not enough. I just swapped this motor back in and the last thing I want is to blow this thing up over something so trivial.
I started it up the day before, just to test and make sure everything sounded good and let it run for about a Min or 2 then shut it off. Then I checked the switch and didn’t feel or see any oil dripping off of it, so I think I'm ok just want to make sure, b/c I just read a post about someone tightening it too much and damaging his motor.
Motor is a black top sr but Ka specs should work seeing as its the stock replacement.
