Then there has to be a malfunction in the return galleries.Q45denver wrote: The pressure improved slightly when they changed the oil and filter again but it still drops off when you rev the engine.
Any suggestion for retifying with the engine in the car-engine flush?maxnix wrote:Then there has to be a malfunction in the return galleries.
Aaaaccccckkk!Q45denver wrote: The tech (who is master ASE and worked for Infiniti for several years) was unaware of that the fittting was BSP 28 thread vs. NPT 27 however, he says the gauge fits tight and was not forced.
Me too. This is screwier and screwier. What's the real story, besides the stripped threads on the oil sensor port? How does OEM sensor thread back in.DAEDALUS wrote:I wouldn't, but really I'm more concerned by the seemingly flawed information.
Thanks for the tip, but I don't think that it since the engine had the same problems with oil pressure prior to them swapping over the oil pump, oil relief valve, and pan from the old engine even though the parts they replaced were undamaged.squeefoo wrote:Is the oil pan pushed up onto the sump? The checkball in the relief valve could have a piece of guide in it, the spring could be bad.Looked at mine today and the relief is accessible from outside just ahead of the #1 header pipe w/a 1" or so wrench. Pull the FP fuse and turn it over catch all the oil (and hopefully crap) in a totally clean pan, look in it with a mirror and blast away with brakleen. It's worth a try.
Edit: I had an Olds 350 seize up right after I installed it because the junkyard set it down too hard and pushed the pan up, it was barely noticeable.
