Oil Leak
matt2299
I am thinking about buying a 240 with an sr swap from a friend. The car's only problem is that it leaks oil from the line that goes to the turbo. The leak is where the line connects to the block. My friend put a new line on and now it leaks worse. I was thinking that I could pay someone to tap new threads into the block, is that a good idea? Does that line go into the block or into an oil sending unit that I can replace?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
get new crush washers, if you dont get the right size or replace them every time, they leak.
