Well you can safely say that the Q crank and rod bearings go first! This is in line with the articles reference to the smallest tolerances of the SHO V8.
You always hear my old such and such American V8 never had these problems........sure with a 3 times wider bearing gap -- oil filter may not matter much.
You can attack the problem 2 ways: Filter after the fact or don't let the dirt in!Again the factory air filter is different than those made for other Nissan.......unfortunately one that would be low restriction [2" W.C.] at 400cfm and filter 1 micron would need to larger than the engine. {{{even if K&N made it}}}
In the past my test of air filters has been to rub a white paper towel on the MAF protective screen and gauge the dirt........makes a cone filter look pretty bad vs a factory filter.
Current LS400 use a larger thicker round cotton/paper deep pleated expensive filter that has twice the resistance to flow of the Q filter [but probably filters the small stuff better].
Just changed my summer oil [50/50 15w50 and 10w30] back to Mobil 10w30 after 92 days and 3100 miles it was dirty [had used some Quick Flush midway and didn't remove it].
Obviously my 239k engine has more blowby [from seals and rings] than a 60k engine [but it is not noticeable at the oil input port at idle or 2,000 rpm -- probably only at high vacuum transitions 70 mph let offs].
If the factory filter won't keep the oil clean then you change te oil when it turns color. Once thought about making an external garage ULTRA Filtration unit but for $25 worth of oil [hardly worth it]....even $100 per year is not worth the mess....you would have to heat the oil to 200F to get a flow.
An external bypass filter makes economic sense if you think about using it [just move it] on all your future cars.
At 55 hopefully I have 20+ more years to drive and Hydrogen won't be here for another 10 and the engine will still use air and oil.
20 microns = 0.000825"
http://www.nissanhawaii.com/Ow...1.asp
What we really need is a really BIG filter system with a 5 times better operation at 0-3,000 rpm then an automatic flip valve to the standard Nissan filter for WOT. Since 99% of the Total life long air flow occurs at maybe a 2,000 rpm average at the highest!
At 60 mph you might suck in 30 x 60 or 1800 cubic feet per hour; at wot throttle you would use 300 times 15 seconds worth or 75 CF.....don't know many that do a WOT quarter mile run each and every hour of vehicle operation.
Is the thought of having another 3 HP at 6,000 rpm and nothing more at 4,000 rpm worth the degraded long term performance of your engine from a marginal filtration filter.
The BMW 1,000,000 miles test was mostly done in the lab so one could assume the air and its filtration [changed every 15,000 or 10 days] was better than a real urban enviroment. Even the outside portion done solo on a race track would be cleaner!
But it sure proves that the car can go 250,000 miles in normal operation just by following the severe oil and all filter changes.
