This one is 100% suitable for any KA-setup. For those of you that know our Pike's Peak Time Attack 240, it runs the trans dapt setup. Not this particular one, but the dual filter one. Hope that helps.robertcoupe wrote:Excellent suggestion. I found this and double checked the threat pitch and the sealing surface of the oilfilter ring
$50!!!!! Sweet.http://www.summitracing.com/parts/TRD-1113/
Modified by robertcoupe at 12:20 PM 10/17/2009
I have this exact kit on my rhd 240sx and running a ford truck K&N oil filter...Well worth the buy.robertcoupe wrote:Excellent suggestion. I found this and double checked the threat pitch and the sealing surface of the oilfilter ringtomkun-s13 wrote:Just to let you guys know. The oil relocation kit for a ford small block V8 like the 302 5.0 motor will work on the kA. We share the same thread pattern so look at summit and save a ton of money.
No leaks at all. Oil level is good and everything looks good when engine is hot.orangeNblue wrote:Just curious 94_240sx if you have had any leakage issues. I'm thinking about picking this up...
Actually, a drain valve came with mine. You can drain oil from the filter before removing the filter from the adaptor.I also don't like it upside down, looks like a future mess.
i have this kit and really like it so farrobertcoupe wrote:Excellent suggestion. I found this and double checked the threat pitch and the sealing surface of the oilfilter ringtomkun-s13 wrote:Just to let you guys know. The oil relocation kit for a ford small block V8 like the 302 5.0 motor will work on the kA. We share the same thread pattern so look at summit and save a ton of money.
