Oil cooler sandwich plate????
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
I need one BAD!!! I cannot find a website that sells them. I have searched till my fingers are blue!! Anyone?
For the rb25
matafied
Car: 1989 240 rb25det 1992 240 rb25det
you could use this
http://cgi.ebay.com/ebaymotors...ZWDVW
just put the cooler in series with the filter
rb25drag
This is the cooler I bought.
Matafied- How would that work without elimintating the filter?
Are you saying run the feed line from the re-locator to the cooler and then to the filter adapter then back to the block?
matafied
yep, have them both in the loop. you might have to have some custom lines to place the cooler were you want it.
like the ones here ( about 3/4 way down the page )
http://www.justjap.com/parts_ncooling.htm
these kits are made to use the cooler and the filter relocated
BoostFab
Car: S13cp, S13fb, S14z
i recommend you running a thermostat with the remote oil filter/ cooler
Carl H
http://www.240sxmotoring.com has a nice greddy plate.
Shocker
Car: 89 240sxHB rb26/30
Carl H wrote:http://www.240sxmotoring.com has a nice greddy plate.
what gasket did you reinstall all that with to the block? is it in the full engine gasket set?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I ended up using RTV since my kit didn't come with a new paper gasket.
Shocker
Darius wrote:I ended up using RTV since my kit didn't come with a new paper gasket.
I consider that but I wasnt sure if it could handle the pressure of the oil system.
You haven't had any issues with leaks?
Darius
I haven't had any leaks from it at all. I laid a 5mm bead on the face and let the RTV set up for like 10-15 minutes before putting the housing on. That gave it some time to cure first.
As far as oil sandwich plates go, they come with an o-ring gasket that goes between the plate and the stock oil filter sealing surface. Set the sandwich plate against the housing, thread the adapter fitting on and you're done. Simple install.
SIL-LINE
Car: S-13 With RB20det
would this work ??
http://cgi.ebay.com/ebaymotors...76100
I too was thinking about doing my oil cooler.
rb25drag
Thanks guys, Carl H-I think that Greddy unit is exactly what im looking for. It also has the Thermo unit built in so that should take car of my oil cooling!!
Also any of you guys ever modified your 240 to make the R33 Radiator fit?
This is the radiator I ended up ordering since I couldn't find any to my liking. The radiator is about 5 inches taller than the original 240's.
Darius
That one won't work for an oil cooler setup. Only for oil gauges. The 1/8"NPT fittings would be too small to do anything as far as cooling. Larger lines need to be used (i.e. dash 10).
BoostFab
rb25drag wrote:Also any of you guys ever modified your 240 to make the R33 Radiator fit?
the radiator fit just fine, just the top bracket that hold down the radiator need to be custom-to-fit.
matafied
while were on the subject of oil coolers, about what tempature dose everyones oil read at? Whats normal?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
http://www.RHDJAPAN.COM has several oil cooler acc's... for the 25/20/26
rb25drag
BoostsFed wrote:the radiator fit just fine, just the top bracket that hold down the radiator need to be custom-to-fit.
Are you sure? I set mine in tonight and my hood likes 2 inches before it will shut.
I have to cut the hood for it to fit! Possibly other mods also!
I would like to know the oil Temps also!
BoostFab
you may need to adjust or bump the lower hook a little to let it set lower.
rb25drag
well I have a 1 inch block under both hooks and I still need 2 inches up top. This radiator is MASSIVE!!!
Im afraid of moving those two front bars down to much! Not sure how much that will affect the handling if at all.
Worse case Ill cut a big hole out of my hood for it to stick threw LOL!! Then Ill get my fiberglass man to fix me something weird up to cover it!
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
well the skyline raidiator fits but its pretty tall heres a pic of a rb25 s14 zenki with one that was parked next to my car at nopi 07 st. louis.
also that greddy oil filter relocation kit on ebay doesnt have a thermost on it so i think you have to run a thermostat sandwich plate cooler kit and just run the relocation kit on top of that.
rb25drag
Well I worked on it all weekend and got it to fit. I had to Cut the Braces out of my hood but it cleared with a little room to spare.
I bought the Greddy sandwich plate with the thermostat built in, So I shouldnt have a problem I hope!
Also built a custom shroud this weekend for my electirc fans. If this thing runs any hotter than 180 Im running it into the first lake I see.
Cameron
Car: a 240
should have just built one yourself and saved you 60 bucks.. you can build the same relocater kit from summit, (4 different parts in all) 7 pieces total for 75 bucks....
rb25drag
I only spent 89$ Im also not re-locating it, Just adding a plate.
Bought it from this place Carl H recommended.http://www.240sxmotoring.com/groilcoadw.html
Cameron
Car: a 240
Ah, so you didnt relocate it? thats cool. I thought you were relocating it.. well but still, to anyone planning on relocating there oil cooler, dont buy the greddy, do it yourself and save money.
oh and i found something cheaper, but theres no telling if they worked for RB's. if you tried one on a KA then it should prolly fit an RB. and this ones fifty bucks cheaper, but it only has 2 ports, and no thermostat..
http://www.jcwhitney.com/webap...10101
Modified by ZenkiCam at 9:42 PM 2/17/2008
rb25drag
Ya Im sure you can save ALot by building it yourself. I just didnt see any reason to re-locate it since I have to jack the car up to change oil anyways. Plus its not in a bad position at least for me.
but thanks for the info, Also can you post the part numbers others will need to build the summit version? Im sure they would appreciate it.
Cameron
Car: a 240
yea i could do that. and did you see the adaptor plate i posted?
heres the Part Numbers...
Six foot (should Be enough) stainless steel line. -10 AN - RUS-632160
Fitting, Straight, -10 AN Male to 1/2 in. NPT Male - RUS-660500 (QTY= 4)
Adapter, Oil Filter Bypass, Spin-On, Aluminum, Natural, 3/4 in. -16 Thread, 1/2 in. NPT Inlet/Outlet - TRD-1013
Oil Filter Mount, Single Filter, 1/2 in. NPT Inlet/Outlet, 3/4 in. -16 Thread Filter - TRD-1028
Fitting, Hose End, Full Flow, Straight, -10 AN Hose to Female -10 AN, Aluminum - RUS-610040
Comes out to 116.45 not including a filter.
(all of this is From Summit Racing BTW)
Modified by ZenkiCam at 4:03 PM 2/18/2008
rb25drag
Sweet thanks for the part #'s im sure guys will thank you for them.
I don't think I seen the adapter plate?
Cameron
Car: a 240
click on the Link in my post above.
Darius
I bought a 3/4"-16 thread oil filter plate and it does not fit on my RB25. The adapter is too big for the threads and too big for the oil filter too. Where did this 3/4"-16 information come from because it is bogus. I'm thinking the fitting is more along the lines of M18 or M20.
Does anyone have the correct info on this?
Shocker
Darius wrote:I bought a 3/4"-16 thread oil filter plate and it does not fit on my RB25. The adapter is too big for the threads and too big for the oil filter too. Where did this 3/4"-16 information come from because it is bogus. I'm thinking the fitting is more along the lines of M18 or M20.
did you buy the plate from 240sxmotoring?
oh n/m I take it you bought that for oil filter relocation? so the threads you thought were 3/4"-16 for the oil filter are really metric?
