why dont you just scrap the adapter plate and run a T fitting off the provided 1/8" NPT on the sandwhich plate? That way you can get both oil pres and temp?Darius wrote:My final plan is to stack an oil cooler adapter plate on top of the sensor adapter plate and put the filter on over that.
Carl, which side did you end up hooking the inlet on your oil cooler? The base of it?Carl H wrote:darius - best bet is to just get the greddy plate as it has provisions for temp and pressure as well as takeoffs for an oil cooler.will be less money spent in the end.
Same I'm about 70-75 lol. Was around 60 before lol.Carl H wrote:lol, i gained pressure due to cooler oil.
your seals can't be too happy with that, haharb25drag wrote:
Hot or Cold?
Cold start I push 100lbs
Hot I hold about 50 Idle and 60-65 cruisen.
I was around 55-60 at idle.
idle psi still seems very high. factory specs are less than half of your numbers at idle, so i don't know what to say. i've run 10w40 before too and the oil pressure does go higher but not that high.rb25drag wrote:When I re-built it I went back with the Pump that was on the motor. Not sure if its Oem or Aftermarket. It held 70+ b/f I blew a piston so I seen no reason to change it.
Clearances ill have to find my machining spec sheet. Its been a while since I went through the numbers. I used ACL race bearings.
I use 10w40 Castrol Synthetic. I wouldnt use anything different, Have never had a problem with Castrol.
LOL again my Mystery Motor!! HAHA,gawdzilla wrote:idle psi still seems very high. factory specs are less than half of your numbers at idle, so i don't know what to say. i've run 10w40 before too and the oil pressure does go higher but not that high.
