oil cooler? ka24de
costa_rican13
Car: 1993 s13 coupe
does anyone have any good reccomendations for any engine oil coolers? like cheap but efficient? or is it one of those things you can go cheap on, like intercooler for example. because i found one from cxracing on ebay for like 120 bucks which i think is cheap and comes with everything i need, like the filter adapter plate, braided lines, fittings and oil cooler, and o-rings. any ideas?? idc about name brand, like greddy, etc.
http://cgi.ebay.com/ebaymotors/16-Row-H ... ccessories
Brent.S13
Car: 1995 Coupe- Totaled
1991 Hatch- Current
The cxracing one should work just as fine. A friend of mine uses it on his S13 and it hasn't faulted on him yet. I'd give it a shot!
supersayianjim
Car: 89 240sx(s13)
DON'T DO IT!!! i brought this kit and it sucked. the only thing iam using is the cooling unit. the oil tree dosn't have a thermostat and that is crucial to make sure your oil isn't too cold for op temps. spend the coin and get a greddy oil cooler tree(ebay for 160.00) and get a coling unit. then get some hp lines. trust me i went the cheap route and iam paying more money now.
also those sid plugs tend to leak(even with tef tape).
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Someone told me to go find an RX-7 intercooler and then build my own kit around it.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
^i dont think you mean intercooler, lol. but yeah the rx7 oil cooler is a good choice. i got one for 15 dollars, and there are loads of them out there!
costa_rican13
Car: 1993 s13 coupe
idk guys. i need some input, if people would help. im looking into getting these for when i have boost my ka.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Build your own -10 or -12. Oil bypass block with remote filter plate, Few fittings and lines.
Mines goes from the out of the bypass block, to the remote filter, out of the filter to the cooler, back to the bypass block.
Cost total was about $250
costa_rican13
Car: 1993 s13 coupe
any idea how to build the -10 or -12? like explain? i never made any type of oil cooler. so im new to this, THANKS!
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
-Earls line assy lube http://www.summitracing.com/parts/EAR-184004ERL/
-Thread sealer http://www.summitracing.com/parts/LCT-37615/
-10 twist tight line (10ft) http://www.summitracing.com/parts/SUM-220789/
-10 twist tight connectors http://www.summitracing.com/search/Depa ... =-10+twist
Sandwich plate or bypass adapted and remote filter adapter
oil cooler Big is good
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Mind you its not a KA
LoserCard
Car: Forest Green 1993 240SX SE Fastback
^^ Your car is teh sex! Just thought I should let you know.
costa_rican13
Car: 1993 s13 coupe
where'd you get the piece that reloacates the filter? or would it not apply to me since i have a ka?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
If you use the sandwich block you dont reloacte the filter, but if you use a bypass block you use a filter relocator.
To relocate the filter use this kit, but you wont use those hoses
http://www.summitracing.com/parts/TRD-1113/
and you need 4 of these
http://www.summitracing.com/parts/RUS-660500/
- remove oil oil filter and drain oil
- install 1/2NPT to -10AN adapters to oil bypass block
- Plumb from the OUT on the block to the IN on the remote mount
- From the OUT of the remote mount to the oil cooler
- From the oil cooler to the IN of the bypass block
You will need 6 -10 AN fitting of the angle of you choice, and 10 foot of line, hardware and time. I used a 25 row oil cooler, and now you get to use a huge Ford oil filter.
costa_rican13
Car: 1993 s13 coupe
i will go your route ^_^. im assuming the middle hole of the bypass block, is pushing oil out?? and the other hole on the outside of the middle hole, is where the oil goes back IN to the block? correct? but also looking on their site i cant find that kit for the ka. :(
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
Awesome info! I was hoping to find some alternative to the $600+ Greddy kit
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
They say in and out next o the holes.
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Really good info! But i got one question. After install oil cooler and line etc. Does motor take more oil or same amount?
costa_rican13
Car: 1993 s13 coupe
it will take more oil because you have to think of the extra space the original amount of oil has to compensate for. (the lines and cooler) so since the ka uses 4 with a filter, i would say maybe 4 1/2 or 3/4.
costa_rican13
Car: 1993 s13 coupe
but also anyone know where i can get the little bypass for the ka??
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
oil bypass comes with that kit. and yeah it will take more oil. Use 4.5 quarts, run for 10 seconds wait 2 minutes check oil and fill to level, then repeat until full.
supersayianjim
Car: 89 240sx(s13)
what is that grey comp can in your engine bay for??^^
and you really don't have to spend $700 on the greddy kit. Buy this
http://cgi.ebay.com/ebaymotors/GReddy-O ... 2c53e710c1
and then this
http://cgi.ebay.com/ebaymotors/19-Row-T ... 2a073c279c
but some earls fittings at a local speed shop. and get some hose from autozone and your done.
i made the mistake of buing this garbage.'
http://cgi.ebay.com/ebaymotors/NEW-PERF ... 3f03ca324e
the tree is s***. and leaked out the side, and it didnt have a thermostat(very important). so iam spending more money because i brought the greddy unit after so don't be jipped..
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Vacuum reserve canister for brakes
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
280zx turbo automatics also came with oil coolers
if you are going the budget route
costa_rican13
Car: 1993 s13 coupe
hbpignosePA wrote:280zx turbo automatics also came with oil coolers
well i can get oil coolers on the cheap cheap, i work at autozone, so i can get hopefully a big one from there. and that kit was for the ka, outtowin?
costa_rican13
Car: 1993 s13 coupe
supersayianjim wrote:what is that grey comp can in your engine bay for??^^
and then this
and idk man, thats one is plate/block is over twice as much as the one outtowin has, any input guys about the summit vs greddy? because the summit makes it away from the block, but also easier to acces and is cheaper. the greddy one is twice as much, and keeps the filter on the block.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Its also a T stat. Some use some dont. I prefer not to use one on my engine.
SX APPEAL
95 Maxima SE 5MT
Out To Win, it looks like summit doesn't carry the brand of kit you have for a KA, they don't even list 240sx under applications for that kit. Looked under Nissan 2.4L and all they have are the 810 and 240Z, don't suppose either of those will kit the KA, would they?
costa_rican13
Car: 1993 s13 coupe
thats what im talking about. so looks ill have to get the greddy one huh?...
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
They dont list every engine or car. Jeez you owe me 10 bucks NOW
but if you search other sites......
http://www.jegs.com/i/Trans+Dapt/969/1113/10002/-1
Trans Dapt 1113 is the kit now its says 95-98 240sx but we all know all KA24DE's use the same oil filter
costa_rican13
Car: 1993 s13 coupe
ok awsome!! so im getting a 25 row cooler for 39 bucks new. now just gotta get all those little fittings.
