zerothread/283967gwoods wrote:Looks like I used almost half a quart of oil in 3,000 miles? Anyone else using oil in an 07?
Running Mobil 1 5-30.
The only thing I could think is I've been trying to get through the 1/4 mile in 3rd gear which means 8,000 rpm. I know at higher RPM's you can have some blow by.
Jeff
A bit off topic, but why do you lower the tire pressure at the track ? Doesn't higher pressure give you better handling ?gwoods wrote:The tires are checked air added as needed and they get a short spirited 'test' drive. I usually run 35 psi in my tires because I frequently exceed 100 mph and don't mind a harder ride in exchange for handling. At the track I let the tires down to about 24 psi depending on the air temp.
Great question. The track I go to is 1/4 mile drag strip. Lower tire pressure makes a bigger contact area and mushy sidewalls. That gives me less wheel spin getting started.chiem wrote:
Alright wise ***! You'll have to admit that the engine does run warmer with the short ram intake as it is sucking in hot air from the engine compartment... that was my point that with a hotter engine and extreme temps over 115 degrees in the valley, you may burn a little more oil than normal...gwoods wrote:Are you sure its not because I have a Fujita intake LOL
gday wrote:1st of all i never said cold air intake sucks...
OEM > Cold Air Intake > Short Ram intake..
Intake systems don't do much really for the price you pay... A simple filter change to a high flow filter should be good enough..
Short ram intake are a waste of money. Other thing the bling factor and the noise they make...
Cold air intake are okay, they work, but they get dirty really quick, and you have to take them out during the rain season...
I'll stick with OEM and a K&N Filter....
And my cousin red line his S2k all day... Doesn't burn oil at all... Something obviously wrong with your G.
I give up please tell us the supense is killing me.gday wrote:Who's the one burning oil and running a hot air intake.. And thinks he gained actual HP because his BUTT DYNO said so?
Ignorance is a bliss.
Actually if you want to get technical....the air will be warmer on a dyno compared to a moving vehicle. When your moving, the warm air from inside the engine bay is being replaced at a very fast rate with cooler outside air (much faster than the small 3.5l engine can use. This has zero to do with oil consumption. If he were to put back on the stock intake system, I would bet my G35 that it would still consume oil...the problem is much deeper than simply the incoming air temp.gday wrote:yeah, do you know how they did those dynos? with the *** damn hood open. hahah..
The short ram does provide better flow vs OEM... but once you close the hood, its sucking in warm air...
So then my faster then stock track times would be because of the butt dyno too? Maybe I'm racing with the hood open?gday wrote:yeah, do you know how they did those dynos? with the *** damn hood open. hahah..
I'm just having fun. I know Gday is always going to say the same thing no matter what. If I posted back - back - back runs at the track with the stock intake - fujita - stock intake and proved the fujita is faster he'd still say the fujita is a hot air intake. It is funny to me when people just can't admit they were wrong.joe603 wrote:Easy there killer....
Remember, arguing on the internet is like winning the special olympics. Even if you win, you're still retarded.
Do it.gwoods wrote:If I posted back - back - back runs at the track with the stock intake - fujita - stock intake and proved the fujita is faster he'd still say the fujita is a hot air intake.
Bet he is faster with the intake. Bet gayday still talks crapchiem wrote:
Do it.
