You might enjoy the test done in Australia on fuels with 20% Ethanolhttp://
www.deh.gov.au/atmosphe....html
"At the test pressure, eight out of ten [fuel pressure]regulators demonstrated a decrease in bypass flow rate averaging 42%. Meanwhile, the remaining regulators AENHY09 (ULP) and AENFO07 (ULP) demonstrated increases of approximately 18% and 139%"
Fuel pumps: "the fuel pumps run on E20 on average had a slightly higher relative increase in electrical current draw after the mileage accumulation cycle. The typical trend was for current draw to increase as the pumps wear. The mechanism for this relative increase in E20 fuel pump current draw has not been identified, but could be suggestive of an increased level of wear.
Ring wear, exhaust valve recession, were increased with Ethanol
"Over mileage there will be a significant increase in the regulated tailpipe emissions for the Australian new passenger vehicle fleet if operated on a 20% ethanol blend fuel.
It is highly likely that certain vehicles will be above the legislated level for ADR37/01 at 80,000km, particularly those with lower engine capacities and engine control system that cannot compensate in all modes of operation for the extra oxygen introduced with 20% ethanol.
Due to deterioration of the exhaust catalyst over the accumulated mileage, vehicles operated with E20 will have significantly higher aldehyde emissions than the equivalent vehicle operated on gasoline.
There is also sufficient evidence to conclude that there was greater levels of wear observed on engines operated with E20 than for those operated with gasoline.
Similarly the levels of engine deposits observed were greater for the engines operated with E20 than for those operated with gasoline."
http://www.deh.gov.au/atmosphe....html
Scarey isn't it! That your government would want to decrease the life of engines and cats with ethanol
