offset?!
M4point5
Car: M Forty Five
ewon1 wrote:
RED_DET wrote:Simple..
put in the width and offset of your current wheels.
compare it to the width and offset of the wheels you wish to run.
It will tell you how much further the wheels wheel stick out and will also tell you how much less of clearance you will have on the inside.
I already tried everything that i could do.
I was curious about how it will be fitting on my car.
I tried to put the numbers in but have no idea what those numbers mean
Easy, it tells you how much poke and backspacing you will have. Go out to your car then measure that distance. Thats where your wheel will sit compared to stock.
ewon1
Car: m37
Cabo wrote:Hopefully because I will be doing the same on my m35 :) soon as I order everything
when are you going to do yours?
