Fibre guy wrote:If your into some simple wiring an AIR-LOGIC (like the V-5300) pressure switch and an adjustable resistor can be used. It would run about $40 total.
First you have the main + wire with an inline resistor to limit the amount voltage running to the pump. Then with the pressure switch you can adjust it to click on at say... 5"HG.When it clicks on it bypasses the resisted wire and lets the full 12v source to the pump.~~~~____Resistor__________~~~~~-+---<____Pressure switch____>---+---PUMP
I made a simple diagram as a reference.
Edit: It doesn't increase the amount of voltage like the others do. I think you would have to look into voltage amplifiers to do that. It would still be under $100... I just like to DIY anything possible & learn while doing it...
Modified by Fibre guy at 2:29 PM 9/29/2009
HAHA I like the DIY idea lol
Thanks for the diagram. I got alot of info now to look into.
These amplifiers would be cool to use. My question would be how long would an electric pump last with 22volts crankin it over? Thats almost double the voltage it was designed for. IMO it would burn up pretty quickly.
As would your idea of the resister and pressure switch. I would think lower than 12 volts would burn it up just as quickly.
I could do a Potentiometer as a resistor for that idea tho.
I will have to re-search what they can and cannot take as a fuel pump has more of a range in amps.
Now at Idle once the car is warmed up. The Intake temps actually rise. I can throttle it to around 2k and it will start dropping the intake temps.
So the flow of my pump is not enough at idle also.
BUT!!!! I know 1 of my problems with the pump. I know I am robbing power from it cause I have it wired in the same Relay as my Electric fans.
I am going to re-wire it on its own seperate relay and switch soon.
But also The water pump has like 18gage factory wires out of it. SO i know the pump will not take more than 15amps before it starts to melt the wires.
Thats another reason IDK if that voltage amplifier would work. I would be afraid of melting it due to such small wires.
Keep throwing idea's at me lol, Im always down to try something new
