Official RBBA Thread - RB Baller Association
RB24D
Car: 1996 rb25det 240
mott6904 wrote:so do you actually have all of that stuff. Or is that your wish list
EDIT:Nevermind I found your introduction thread. I love your parts bin. My trunk looked the same for a while. Do you have any more pictures for us to look over
I can make some this evening if you like
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Yellow4g63 wrote:IDK if my RB20 is baller enough but I'll throw the mod list out
You have a rips intake mani. Thats baller on it own.
stevespeed
Car: RB-Swapped S13, FTW
I guess I could be part of this now, I just recently purchased my RB25DET for the ungodly deal of 800 dollars and I am looking to get it into the car soon, running a stock setup, but after its in and I get some more money together, There is no limit to what I might do Here is some pics of my new baby
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
Booztd 3 wrote:Can I add this to the list....
My workbench
holy hell! what turbos are those?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
stevespeed wrote:I guess I could be part of this now, I just recently purchased my RB25DET for the ungodly deal of 800 dollars and I am looking to get it into the car soon, running a stock setup, but after its in and I get some more money together, There is no limit to what I might do Here is some pics of my new baby
You must be confusing the RBBA with the NRRBA. Non-running, bare stock block /= baller. Application denied
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
Darius wrote:You must be confusing the RBBA with the NRRBA. Non-running, bare stock block /= baller. Application denied
+1
BTW, where's your post Darius, or does everybody here already know you're a baller? No need to post.
stevespeed
Oh come on man, we all started some where! come on! lol
Modified by stevespeed at 10:49 AM 10/16/2008
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
yeah sure we all started some where it just so happens that this is a thread for highly modded RB motors hence the baller status...
read the first post you my friend are no baller with your 800$ motor.... thrifty maybe but no baller
stevespeed
toadx8u wrote:yeah sure we all started some where it just so happens that this is a thread for highly modded RB motors hence the baller status...
Give me time my friend Give me time
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
we have all done our time darius and i have both had rbs for prob almost 6 yrs now...idk about some of the other guys...but there are some serious vets here...
SO ANYWAY....COOLWHIP WHOS ADDIN ALL THESE POINTS UP I WANNA KNOW MY SCORE....LMFAO im not counting on carlos to do it...
StricNyne
i had a rb when they didnt even come in skylines...
240z4u
Car: '95 Nissan 240SX
toadx8u wrote:we have all done our time darius and i have both had rbs for prob almost 6 yrs now...idk about some of the other guys...but there are some serious vets here...
Todd needs extra points since his car has already seen 11s, thats more baller than most of the crap I see on this site... fancy pants manifolds or not.
Points deduction for NRRBA members with loads of parts.
cdorhout
Next project TBD
Give me slicks and I'll give you 11s.
I was hitting 12.5 et with stock internals and low boost and street tires, now I have forged internals, 25lbs of boost and 3.0L, so I damn well better be in the 11s by now! I just haven't been to the track all season.
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
no slicks man just drag radials...thats all you need...i mean come on if guys can go 7s on 10.5 radials you should be ok with them...slicks require driveshaft loops and tech will wanna check for it
mott6904
Ive had my rb for about 5 to 6 years. I did the swap when i was 16 for my school project i guess i will throw up a list since rb20's are allowed.
r32 rb20det with 60,000 miles Made my own mounts Wiring by me60-1 turboHks 50mm wastegatehks bottom mount cast manifoldCustom earsl turbo oil linesPorted and polished headcomplete head rebuilt by perfessional machine shopKelford 10.2 lift 260 duration camskelford valve springsBronze valve guidesCometic head gasketcometic intake gasketArp head studscustom front facing greddy style intake manifoldq45 throttle bodyNgk spark plugsaeromotive regulatorLiquid filled fuel pressure gaugegreddy fuel railwalbro pumpz32 fuelCustom earls fuel linesGreddy type r bovHybrid fmicApexi filterGriffin radiatorflex-a-lite dual pusher fans with built in shroudpainless thermo switchnismo lower temp thermostatgreddy timing beltOem tensioner and idler pulleyN1 water pumpn1 oil pumpGt spec exhaustcustom 3' downpipe built be mebuilt my own charge pipesGrand national coil conversionmsd plug wires with custom made brackets.Aem tru boost controllerAem oil pressure gaugeQuest alternator upgrade and custom bracketcustom thermostat housingAll pipes have thick couplers with t-bolt clampsAll new beltsAll new hosesAll new seals in the engineAll new fuel lines vacuum linesAll new fluidsExedy hyper single clutchnismo pivot boltNew throw out bearing custom earls stainless clutch lineS15 hlsdNismo ring gear bolts5 lug conversion hubs for front and backFront and rear z32 calipersFront and rear brembo slotted and drilled rotorsz32 brake master cylinercustom earls front and rear stainless steel brake linesProject Mu padsEnergy suspension bushing kitBoxed in my rear suspension armsTein basic coilover kit and camber platesBigger sway bar(dont know the brand)cheap wheels and tires(they were free and 5 lug)new tie rodsnismo slave cylindernew clutch master cylinder Earls power steering hose and fittings
I just copied and pasted this list so there is probably some things that arnt engine related. Hey ref. do i get any points?
OpeLok
medium ballin
SARD 550cc injectorsSARD FPRT04E turbocustom IC pipingcustom IMZ32 MAFApex'i Power FCTial 38mm WGGreddy EBCInnovate LC2 Wideband O2SpliteFire Coilpacks20psi
http://www.youtube.com/watch?v=hSGtcezrTNQ
Modified by OpeLok at 6:46 PM 10/17/2008
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Way too lazy to list all of the parts. Pics:
ANVIL
Car: RB25DET S13.5
wow, good stuff guys... even without a modlist, i can see that mattblancarte is
Booztd 3
Car: 1990 Nissan 300ZX TT
11's w/out slicks FTW....
Hell the tools were in the hatch area...and 3700~lbs
Made some tweaks, should have a 10 second slip this weekend....
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
bout time i chime in. pics explain it's self. This is round 2 for me and a new chasis. Working on a 240z chasis to drop this in. Also has apexi power fc i got for $850. Anyone still in the market for one i'll point you in the right direction.
http://videos.streetfire.net/v...0.htm
her first wot run many many moons ago!
eh?
Bah it's actually been SIX LONG years since I first started with the swap. I'm tired an old, I actually prefer to drive my G35.
http://www.youtube.com/watch?v=yHlWZjq8sQg
StricNyne
sup eh! i met u and scooped up that long block u had !
eh?
StricNyne wrote:sup eh! i met u and scooped up that long block u had !
wsup, what did you end up doing with that thing?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Carlos is so baller that he uses it as a coffee table in his guest bed room in the guest house of his weekend beach house in Miami.
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
and im so baller i have 3 rbs and 5 240s...bahahahaha
eh? wrote:wsup, what did you end up doing with that thing?
iirc thats the one hes been building
Modified by toadx8u at 12:39 PM 10/17/2008
eh?
toadx8u wrote:and im so baller i have 3 rbs and 5 240s...bahahahaha
For a while I had 4 RB's, one complete long block (which StricNyne has), one built internals (went bad, don't ask), one disassembled in my basement, and the one in the car.
I ended up giving most of them away for free. I moved so there was no point in keeping them at my parents house and it wasn't worth it to ship.
StricNyne
nah i got the big dawg in the car adn yer block i am building when i goto iraq
kevwa
Car: 95 Chevy S10 RB25DET
even though i dont have a built motor and am not making high hp yet, i figure i have enough to post - so you guys be the judge
RB25DET in S10 - this alone should be some points - custom motor mounts- custom transmission mount- modified S10 driveshaft to accept the RB yoke (will have new one made as soon as i finish my new rear end conversion - doing an 8.5" GM with locker)- Walbro 255 fuel pump- Nissmo afpr w/ inline gauge- converted to GM grand national waste spark setup- front mount intercooler/piping - top mount manifold- Garrett T3-TO4E- custom downpipe and exhaust- soon to be running on MegaSquirt
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
I have 2 25s both which came from ebay...1st one has 3 bad cyls but carried me to the 12.2 with no mods(plans for a stock rebuild and drop in my vert)...2nd one carried me to 11.6, i just washed a cyl on due to some cheep 550 injs(dwerks) that i think stuck, and im tearing down this weekend... and the rb26 i have came from Bizerk who was on racebread alot idk about on here...it just needs a rotating assembly and its goin in the 97 drag car...
Coolwhip
Vendor
Hey Todd, you know who to come talk to
