Official DIY ECU EPROM programming discussion
biosehnsucht
the VG tuning site I linked above also has a good explenation of how the ECU works
Vetal
If that was meant for me, it still doesn't explain the fact I gave
biosehnsucht
It was meant for you and I'm too lazy to try and figure out whether what you saw before was wrong or if you goofed up the calcs somehow or if its a damn gremlin. :P
Vetal
I didn't goof them up That's for sureMight be that my Techedge distorts the signal... i.e. it sees lower voltage on AFM than there actually is
nab911
Car: 93 Nissan 240SX SE
Well its time to rehash this thread . I finaly got my eprom programmer to write to a chip so i dropped my ecu off today to get chipped. I think i still have the old ca18 bin files but i forgot exactly what parameters i needed to change for what i have setup. I need to alter the file for 460cc injectors (rx-7's) and the sohc ka maf and a huge t3. Anyone got any suggestions?
Pumaking
yea get a better MAF cause your gonna max it out I believe around 220hp or was it 190 either way your ka maf is gonna hinder your motors potential.
nab911
Im just trying to get rid of the stumble at 4lbs because im maxing the ca maf out (200hp). I thought the sohc maf could take ~275?
Pumaking
from what I read the CA and SOHC KA maf are exactly the same. only difference is like an extra wire on the plug.
nab911
Can anyone else back this up before i go spend money on a z32 maf??
c-rad
Car: 1991 Nissan 240SX w/CA18DET
SOHC KA MAF is only good to like 230-240hp MAX. It has a slightly larger diameter than the CA MAF, but the voltage curves are nearly identical. That's why you can use a KAE maf as a substitute for a CA/SR maf without any ecu changes.
nab911
Anyone got a z32 or a cheaper alternative
Pumaking
well you can go with either a Q45 MAF, N60 MAF which are out of early MAximas. The maxima maf usually got for $30-$50.
WeldingHank
Car: 1989 240sx CA18DET
Maxima MAF, can do 350HP.
Dattebayo
I see the N60's out here all the time. They are on J30's, I30's, maximas, 91-95 (96?) Z32's, etc.
They are easy to find for sure. I can get you one here for $70 if you cant find it easily.
c-rad
J30 is an N62 (orange tag)... same as the Z32. 89-94 Maxima uses the N60 MAF (purple tag and looks physically identical to the N62 Z32 one). The 95-99 Maxima/I30 is different and I don't think can be used.
Dattebayo
no, early J30 has N60 I have seen them. Not all Z32's have the N62, only the later years. I have seen this as well.
I believe that the N62 started appearing in Nissans somewhere about 1995 or 1996. It was not available before that.
c-rad
2BN_S13 wrote:no, early J30 has N60 I have seen them. Not all Z32's have the N62, only the later years. I have seen this as well.
Uhh... I pulled a MAF off a '93 J30 (first model year) and it was a 22680-30P00 N62 MAF. The 90-96 300Z and 93-97 J30 both use the exact same MAF seeing as it is the exact same engine.
c-rad
Actually... I think they might have switched on the J30 in '96 with the advent of OBDII. I don't think its an N60 though as that is definitely an 89-94 Maxima MAF. I know the one that comes on the 95-99 maxima uses an oval plug rather than square.
Pencil Shavings
hey will this eprom programming also work for a turbo'd kade?
c-rad
Pencil Shavings wrote:hey will this eprom programming also work for a turbo'd kade?
KADE needs a daughterboard soldered into place as it is a 16-bit ECU. Sorry.
Pencil Shavings
So there is a way to reprogram it though?
If so you do you have any links handy specific to it?
thanks!
Pumaking
just go ahead and search
http://www.bikirom.com
nab911
Anyone have a maf they want to sell me Ill take any that can handle 300+
datsunboy
Car: Datsuns
so can anyone else confirm that the N60 MAF can read 350HP???I didn't think it was quite that much.My MAF is from a R32 RB20DET skyline. and is a N60
c-rad
datsunboy wrote:so can anyone else confirm that the N60 MAF can read 350HP???I didn't think it was quite that much.My MAF is from a R32 RB20DET skyline. and is a N60
I always thought it was the same as the RB20 MAF at 300-310hp.
fanta
I go with their guidelines:http://www2.osk.3web.ne.jp/~t1....html
nab911
OK so i need a definate answer on these mafs. Junkyards around me have them everyone but i need to know if i should get the z32 or the 89 max because there is a huge price difference
Dattebayo
If you go to a pick n pull not so much
c-rad
nab911 wrote:OK so i need a definate answer on these mafs. Junkyards around me have them everyone but i need to know if i should get the z32 or the 89 max because there is a huge price difference
That sucks... the junkyard here charges $15 no matter what the MAF comes off of. I say just get the Z32 and be done with it. The VQ maps are readily available for it.
datsunboy
Car: Datsuns
crap.....we dont have pick n pulls in NZ.most dismantlers know that the Z32 MAF is the biggest and everyone wants them so charge around $300 for a Z32 MAF....and only $70 for a skyline N60 MAF
