Let's also keep in mind that maybe 2% of the people in this forum have the need to go beyond the factory engine management. What exactly are the 'limits' of changing the maps in a factory ECU? The only limit I see is using a MAF system which really isn't a limit unless you are exceeding it's capabilities and in the case of the Z32 MAF, that's closing in on 500hp.float_6969 wrote:I'm not baggin on anybody setup, but please take into consideration that an ECU tune has it's limit. If you are looking to do anything more than a larger MAFS, 550cc (or around that) injectors, and a T28, I would consider other options besides an ECU retune. You are still dealing with computer technology that was written and designed almost 20 years ago. Not to mention the fact that an 8bit ECU is pretty slow by todays standards. Don't get me wrong, a tuned ECU is a great alternative if you have the ability to do the tuning yourself (I LOATH the idea of a pre-programmed ECU, as every motor and set up is different).
Just something to keep in mind...
I posted it a couple threads below this one yesterday... but here is the direct link anyway... I figured I would host it because the only link I could find was down....nocwage wrote:Sorry.. where do we find Live Edit?
Yeah, that's the forum I was on. There are many people who go off an ECU tune alone with plenty of success. You just need to know what you are doing.fanta wrote:Even an 8-bit system has immense processing power in regards to what we need for our engines, more than enough for tuning all of the regions on the fuel and timing maps. It can handle the functions necessary to keep the motor running many times over as it is. There are a number of basemaps you can play with on the Ztune forums, along with a number of helpful members, great site.
You are right, but that limit is something that most people on this board will never see.float_6969 wrote:I'm not baggin on anybody setup, but please take into consideration that an ECU tune has it's limit.
Where did you come up with that? I have used DIY EMS for more power and bigger injectors that you are talking about.float_6969 wrote:If you are looking to do anything more than a larger MAFS, 550cc (or around that) injectors, and a T28, I would consider other options besides an ECU retune.
Anyone? Bueller?c-rad wrote:I was looking at a few things and noticed that the some of the ECU's don't have a table for O2 voltage. I assume this is for the non-catalyzer model cars. My question is, is it possible to copy the .BIN file from a non-catalyzer car and use it in a Japanese ecu to eliminate the O2 sensor?
Another question I have... My motorset came with an automatic ECU and harness. Some people have said this is fine and the motor will just not have a rev limiter or speed limiter. My question is, can I use the M/T .bin file on the A/T ECU without issue? If I can't it's no big deal as CA ECU's go for $50 everyday on Ebay. But if I can use it, then cool. I'd like to get into further discussion about what part of the tables to modify when upgrading the turbo, etc... But if anyone can answer my questions so far, that would be great!
You can do it Eeeeeeeeeeeeeeeee-bay!originalsin wrote:where can you get the socket and eproms??
I thought that I made it VERY clear that I wasn't looking down on anybodys setup or tuning an ECU. And in actually, it's really not so much the ECU that I am lacking faith in, but in Nissans superflous solenoids and valves. I have been personally fighting with them for years now and I finally gave up on them. I also reached a point in my building that wouldn't cover the capabilites of what the ECU could do. I also greatly wish to simplifiy things too. I am sure that you could tune a stock Nissan 8-bit ECU to run a Q45 MAFS, AND 880cc injectors, but do you really think that is the best way to go about it? I have also seen the maps in the stock ecu (as I've contemplated ECU tuning before) and they have limits that, to my knowledge, can't be exceeded. EX: tuning the motor accuratly past 6800rpm. Unless you have a different software than what I have, you can't really do it. Just about any decent upgrade in cams will render the capabilites of the stock ecu lacking. I'm not saying it can't do it, but I don't think it can do it well.Turbogixxer wrote:
People talk about DIY EMS with a blind taste, then they see what you can do with a low price, and all of a sudden they are believers. Try to keep a open mind to it. The systems are not for everyone, but they are hardly crappy EMS.
I would say that CA18DET motor also was designed almost 20 years ago... And since our motors still run those 7000rpm (+/- 500), and not 15000, it's processing power is absolutely sufficientfloat_6969 wrote: You are still dealing with computer technology that was written and designed almost 20 years ago. Not to mention the fact that an 8bit ECU is pretty slow by todays standards.
Thats actually what I'm going to order properly, not sure if it'll really fit in there (the specs say its x height but it doesn't look it, and that # is a bit big..)originalsin wrote:so i would want thishttp://www.jameco.com/webapp/w...02744
I can't see anything regarding my question in there
