Short video from 20-60 mphI missed 2nd gear as you can tell.I am still tunning the fuel, It is running high 9 to low 10 AFR @ WOT and 14psi of boost.I hope to get on A dyno in the next couple of weeks.
http://s153.photobucket.com/al...h.flv
<<<<Engine Setup>>>>CA18DET stock internalsMitsubishi s20G turbo TDO6H-20G-TDO5H-10CM2Top mount manifoldHomemade o2 pipe3" SSAC from o2 pipe backSSAC FMICMines tuned ECUSAFC-2Wideband O2 sensor with LM-1 simulated narrow band to ecuDSM 450cc injectorsZoom stage 4 clutchTurboXS RFL BOVTurboXS MBC @ 14psi
Modified by tattman77 at 1:14 PM 5/5/2007
